gotta a question???
Old Oct 20, 2006 | 07:59 AM
moose's Avatar
gotta a question???
gettin ready to paint my headlight, and i was just wondering if i can just paint them the way they are or do i need to sand them any first....thanks guys....
by the way the car is silver, should i use flat black or a high gloss....
Old Oct 22, 2006 | 01:08 AM
Belto's Avatar
I didint sand it and no problem,, just prime it and paint,,, go flat black,, dont like the glossy look IMO,,, just make sure you seal them very very well,, and dont touch the iner part of the clear part of the headlight...
Old Oct 22, 2006 | 01:25 AM
rally's Avatar
This does not belong in the "How To" Section, next time post in Apperance and/or use the search button.
As for the question, you need to sand, if you do not after awhile the paint will flake off. And it dosent matter if you use flat or glossy, but glossy will make it look complete on the car, seeing as the car is glossy and not flat.
Old Oct 22, 2006 | 01:51 AM
xspyder85x's Avatar
i would prolly go with glossy also, make sure you seal the headlight
Old Oct 22, 2006 | 01:58 AM
rally's Avatar
Definetly make sure you seal it good. I thought I had it then I powerwashed it and BAM! Instant fog. Then I took em out and resealed them, swore they couldnt get water in them, and somehow they're worse.
Time to get projectors? I think so.
Old Oct 22, 2006 | 04:56 PM
BlackLS's Avatar
What grit sandpaper did you use and what kind of primer did you use?
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
