halo fogs
replacement wand (clear) -homedepot
led color of your choice (3mm th others are too big for the 1/4 " wand)-radioshack
220 ohms resistor -radioshack
dremmal tool
oven
electrical tape
depending on the side of replacement wand 1/2 " or 1/4 " yo will need to find an object that will make a 3 " ring. so if you use the 1/4" wand you will need an object with a diameter of 2 1/2". if you use the 1/2" wand you will need and object with a diameter of 2 ".
i believe that's it
dremmal tool
oven
electrical tape
i believe that's it
As for the dimness near the one end why not just add another to the other end?
So basically all you do is heat up the wand and bend huh? Interesting... what did you heat them up too? Then all you need to do is cut into the want to create the lines and add the LEDs I assume.
my fogs still fit in the middle just haven't gotten them yet should be here any day now
