Headlight Housing Question
Old Aug 10, 2006 | 06:25 PM
Cobalt_SSTuner's Avatar
Ok, I know this is like the 100th repost, but I just have a few questions about painting the headlight housing.
1. Should I sand the chrome housing?
2. Should I use a clear-coat?
3. If I use the oven method to take apart the headlight, what temp should i set it at and how long?
Thats really the only questions I have. I plan on doing it on saturday. If there are any tips or extra advise that you think I should know, i would greatly appreciate it if you shared. Thanks for your help
Old Aug 10, 2006 | 06:44 PM
bump.....c'mon guys, I could really use the help.
Old May 25, 2008 | 05:08 PM
OneSlowGto's Avatar
Damn this thread is rocking.
Old May 26, 2008 | 10:32 AM
StealthSS's Avatar
i did a light wetsand. make sure the surface is clean as well. I didn't use clear coat, but i imagine i could. And I don't personally suggest the oven method. A hairdryer on high works fine and gives you more control as to not damage the headlight.
Old May 26, 2008 | 10:37 AM
HidKidSS's Avatar
sanding if if u want 2 i didnt n it still looks kick ass
i used a clear coat couse i have hids but the clear coat made it look dull but i still used it an added another blk coat over that
an yes use the ovan its the easiest way...set it to temp 200 let it preheat then set the timer for 25mins per headlight
hope that helpd
Old Dec 17, 2010 | 12:25 PM
Seven11's Avatar
Disassembly
I plan on disassembling my Depo projectors. Do I re-use the advesive or do I need to purhcase new adhesive to seal it?
Old Dec 17, 2010 | 12:46 PM
dillw33d's Avatar
I reused my sealant just fine with mine. I pressed them on so they'd stay in place while I baked them, and pushed hard when I took them out. Works fine!
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
brandon04
Oct 21, 2015 07:04 AM
Slick_Nick
Sep 28, 2015 09:15 PM
