Help with how to sand center console and paint
Old Dec 18, 2013 | 12:12 AM
deceased10's Avatar
Hey guys haven't posted in a while but figured I could post here for some help I need on a paint job I am trying to get done.
So let me explain, I put my car away for the winter and decided I'd start a project of painting the top pieces of my center console. But I didn't want it to look oem I want it to look smooth and glossy like fiberglass kits.
So I started sanding away for a few hours on my pieces, but I am just scared it won;t turn out good. My main question is, am I doing it right? Or should I be doing it another way?
Ill post pictures as you can see all the bumps are gone but its really scratched up from using a blade to remove the bumps and then I sanded.
Now do I just paint now? will it turn out smooth? Do I use filler primer? Or do I keep sanding using different grit? I just want it to be perfect as I am a perfectionist. I'd hate to spend money painting it and have it all scratched or messed up.
Old Dec 18, 2013 | 01:36 AM
andrewcarr1993's Avatar
I'd say smoother then filler primer multiple times with sanding in between. Really though depends on how nice you want it to come out, looks good through the window or the car or looks good 6 inches from it.
Old Dec 18, 2013 | 01:42 AM
Seems like a neat project id like to try. Advice i have is keep sanding and yeah like guy above me said filler primer with sanding between coats. Do a gloss layer on top, then wetsand that
Disposable-Hero's Avatar
Same thing he said. Sand with a finer grit, then filler primer with more sanding.
Wish I would have taken more time on my trim.
Old Dec 18, 2013 | 03:29 AM
deceased10's Avatar
Thank you for the advice! Definitely has to look good 3 inches from it haha. So your saying I should toss a coat of filler primer on it then sand? And then primer and sand again? Should I use finer sand paper every time?
Old Dec 18, 2013 | 03:54 AM
SPDDMN36's Avatar
exactly, and like riceburner said, finish with a glossy clear coat and wet sand. then wax
Old Dec 18, 2013 | 11:35 AM
intel's Avatar
This is what I did for the below pieces... sand (low grit/coarse), prime, wet sand (high grit/fine), prime, wet sand (fine grit), skim pieces with glaze putty, wet sand, spray, clear coat.
Old Dec 18, 2013 | 11:41 AM
Using the filler primer will make low and not well sanded spots stand out more, if you want perfectly smooth then you need to repeat until you think its good, and then do it one more time.
Old Dec 18, 2013 | 06:06 PM
deceased10's Avatar
You say use glazing putty? What does that do?
is this is Bondo Light Bodyfiller | Canadian Tire
Old Dec 18, 2013 | 09:21 PM
intel's Avatar
Glazing putty + wet sanding is the last step before you're ready to spray. The putty is used to fill any pinholes that you may see.
Old Mar 13, 2014 | 03:58 PM
deceased10's Avatar
What grit should I be using?
What grit should I start with and in between and what should I end with? Not sure what grit to go and buy
Old Mar 14, 2014 | 12:05 AM
intel's Avatar
For my pieces I did the following...
Primed, wet-sanded with 320 grit, primed, wet-sanded with 320 grit, applied glaze putty to any pin holes, wet-sanded with 320 grit to, primed, wet-sanded with 600, sprayed base coat + clear.
Oct 20, 2015 09:56 PM
Oct 13, 2015 09:32 PM
nathan112i
Sep 30, 2015 07:12 PM
metroplex
Sep 27, 2015 07:48 AM
