Help please w/ projectors asapp
Old Mar 11, 2007 | 04:12 PM
l Sh1ft l's Avatar
Ok. Been trying to follow the tutorials on here but we keep ending up w/ this.
*Only 1 of the 3 marker lights, light up
*With the brights turned on, the brights work, yet the halos still are not on.
We have all 3 white wires, spliced into the brown side marker light. One black wire coming from the 3 marker lights is spliced in w/ the black side marker wire. The last 2 angel eye black wires are grounded to the chassis.
I don't know if you guys understand any of that, but pleaseee help.
Thank you!
Old Mar 11, 2007 | 05:09 PM
HotWheelz's Avatar
I had a lot of the same issues. I went back through and checked all of my connections and the ones on the lights themselves with a voltmeter. All of the wires seem to be fine, it is the bulbs and some of the sockets that are defective. One of my halos still doesn't work, my driver side high beam doesn't work, and 4 out of the 6 LED's don't either. So I'm ordering new leds and most likely new sockets for them as well so that I know their done right. My only issue is finding an LED that looks even remotely like the one they used in the Halos. For what we paid for these I can't believe what crappy workmanship went into them.
Old Mar 11, 2007 | 06:16 PM
06VRCoupe's Avatar
Only 2 of my leds up top don't work. Everything else for me works. I followed mkurleys How-to if that helps.
Old Mar 11, 2007 | 06:39 PM
mkulrey13's Avatar
they use 3mm leds in the halos which i have in all colors
Old Mar 11, 2007 | 06:41 PM
JPizzle's Avatar
I think I have a problem with mine, I only have 1 beam on the ground w/ the low beams, & I have tried to aim them... But it's not working out too well.
Old Mar 11, 2007 | 07:24 PM
Xavipheus's Avatar
If this makes you guys feel better, all my wiring was right (Sodderd) and one of my halos didnt work and one of my leds didnt work, and then like 2 weeks later they just came on and have been working fine for like 2 months now
Old Mar 11, 2007 | 09:28 PM
cobalt8's Avatar
Ouch bad luck I guess, I ordered mine off ebay and everything is 100% functional.
Old Mar 12, 2007 | 12:22 AM
Florida 76's Avatar
yes i hooked mine up like the how-to said.... white wire to brown and black wire to black.... and mine are 100% functional
Old Mar 12, 2007 | 01:23 AM
My06Coby's Avatar
Pull the bulbs out and make sure they're connected right. + to + and - to -. I had this problem with mine as they were backwards.
Just make sure not to touch the wires togther while the lights are on or POP! Blown fuse
Old Mar 12, 2007 | 08:52 PM
Blankobalt06's Avatar
X2. Mine work great this way.
Old Mar 16, 2007 | 03:54 PM
l Sh1ft l's Avatar
Update:
Took um in and got everything installed. It's all good except on 1 side, 2 of the 3 LED's do not work. Where would I be able to pick up the right size and same color bulbs?
Also... Did anyone change the color of the bulb to the right of your halos? Think it's the day-time running lights. Or did you guys just keep um the yellowish. Thankss
Old Mar 16, 2007 | 05:32 PM
VeNoM0713's Avatar
ok.. the link for the 3 leds on top is..
http://autolumination.com/194.htm
now scroll down to the middle of the page until you get to Oval Wide Angle Lenses. and there you go. i just ordered a couple of em
Old Mar 18, 2007 | 01:36 PM
l Sh1ft l's Avatar
Thankss
TedSS
101
Apr 25, 2016 10:46 PM
Bluelightning
Nov 11, 2015 02:41 PM
chefhhr
Oct 26, 2015 10:36 PM
allpro666
Oct 6, 2015 08:11 PM
juandirtymessican
Oct 27, 2012 10:41 PM
