Help with projector aiming
Old Oct 4, 2012 | 11:09 PM
Smithkid21's Avatar
I have the dreaded Gen 2 Projectors with 8k HIDs in them. I do plan on getting some retrofits sometime soon. But I was wondering, are these aimed up high enough? Cause I personally feel like they're too low, but its hard to decide with the check mark __/ style cut offs. So, do you think these could be aimed up more? (I do apologize as its not the best picture I got, so I can get another if needed.)
Old Oct 4, 2012 | 11:21 PM
Sox-Fan's Avatar
Got Brakes?
https://www.cobaltss.net/forums/appe...way-do-284934/
Old Oct 5, 2012 | 08:34 PM
Smithkid21's Avatar
They're not retros though. I was wondering if there was any help seeing these cutoff's suck.?
Old Oct 5, 2012 | 08:43 PM
Omnigear's Avatar
easier way, take off bumper instead of taking the headlights on and off.
unless you have that flexible Phillips drive.
Old Oct 5, 2012 | 09:34 PM
Sox-Fan's Avatar
Got Brakes?
big deal, they're not retros. mount in the same place. use the same two adjusting screws. Should be at the same height. block or brick wall still works the best.
Did you look at the title and decide not to read it, or did you read it and not understand. Because if you didn't understand I'll help you. If you didn't even read it, you're wasting my time.
Old Oct 6, 2012 | 02:13 AM
Smithkid21's Avatar
Before you ASSume, I did read it; awhile ago. But I did look over it again. I just didnt know if there was a difference due to the cut-offs. But seeing as you insist on them being the same. I'll aim them according to the how-to.
TedSS
101
Apr 25, 2016 10:46 PM
Bluelightning
Nov 11, 2015 02:41 PM
chefhhr
Oct 26, 2015 10:36 PM
allpro666
Oct 6, 2015 08:11 PM
Extreme Dimensions
Sep 24, 2015 07:51 PM
