hid install help
Old Feb 3, 2011 | 09:55 PM
09Sp0rt's Avatar
hid install help
ok so long story short i tried to install my hid kit last week and they didnt work... this week there was a blizzard so i cant try again but i would like to get some suggestions as to why they would not work... now obviouisly im not dumb and can connect a few simple wires, im thinking its something to do with my relay maybe???? Only my highs came on, any suggestions are greatly appreciated
Old Feb 3, 2011 | 10:01 PM
mkulrey13's Avatar
Check your pins in the 9007 connector. they seem to always bend when the install is rushed or those connections pushed together fast.
09Sp0rt's Avatar
they are both straighter than ever
Old Feb 3, 2011 | 10:04 PM
09Sp0rt's Avatar
only thing i can think of (which would eat my words from being able to 'plug in some wires' ) is that if i plugged the relay into the ballast wrong??? I mean the clip goes over the triangle shaped one notch in the ballast right???
Old Feb 3, 2011 | 10:06 PM
mkulrey13's Avatar
Relay has nothing to do with your high/low function. These are plug-n-play.
Old Feb 3, 2011 | 10:08 PM
09Sp0rt's Avatar
im stumped then.... if the pins are the only thing then i have no idea....... i will try again this weekend and mess around with it and try and figure it out =/
Old Feb 3, 2011 | 10:09 PM
09Sp0rt's Avatar
btw mkulrey, did you see my message? ^^^^ which way do the wires plug into the ballast, clipped on to the triangle ( i think its triangle ) or the small square one
mkulrey13's Avatar
Make sure the pins in the connect are not pushing out and not making a connection.
Old Feb 3, 2011 | 10:12 PM
royce777's Avatar
check your fuse. possible put a higher fuse
Old Feb 3, 2011 | 10:26 PM
mkulrey13's Avatar
Yes the plug on the ballast clips over the smaller lip.
Old Feb 3, 2011 | 10:27 PM
royce777's Avatar
and do you have the ground attached properly?
Old Feb 3, 2011 | 11:39 PM
I dont have a pic of the wires but there are 2 that have to be spliced into a 12source and a ground that control the high/low shield and halos (or at least on my retros i bought from mkurley13) didnt have those wires connected, lights worked but only highs, hooked the wires up and then my halos and high/low worked
Old Feb 4, 2011 | 01:20 PM
09Sp0rt's Avatar
well i dont have projectors, this is just a simple install in some painted stockers
Old Feb 4, 2011 | 02:40 PM
Cobalt08LS's Avatar
defff check your fuses dude.
i had the worst problem ever and it was a dead ballast and blown fuse
Old Feb 4, 2011 | 03:41 PM
09Sp0rt's Avatar
fuses are good... suppose i had the relay plugged into the ballast backwards... suppose that would fix it???
Old Feb 4, 2011 | 05:39 PM
Keithvibe's Avatar
are you sure the wire harness is wired for 9007? usually they are wired for 9004. In which the ground and power leads need to be swapped around.
Solaris99
28
Mar 15, 2017 01:22 PM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
Bohb
Sep 27, 2015 09:11 PM
