HID Install help!
Old Jun 27, 2012 | 08:54 PM
07balt_ss_sc's Avatar
HID Install help!
Hey guys, so i just installed Xentec Hid's in my headlights and foglights, everything worked fine, drove home went to look at them again and the fogs are not working!?! I checked the foglamp fuse that was fine, i checked the connections and they were fine, any ideas? I hear you are sposed to buy a relay along with the kit to make its own power source in a sense? but I just dont understand why the headlights are working fine and the foglights went out
Old Jun 27, 2012 | 09:01 PM
zerosk8ter83's Avatar
check your power source and ground
rogersj's Avatar
check power going to ballast
Old Jun 27, 2012 | 09:07 PM
thats the thing, i was looking at installtion vids and such, and i connected nothing to ground or the remote battery terminal and all the threads are showing connections to an external source not the factory harness..
Old Jun 27, 2012 | 09:13 PM
K-Train04RL's Avatar
those are the relay harnesses.
most likely have a bac connection. wiggle them all. try again.
Old Jun 27, 2012 | 09:31 PM
do i need a relay harness? it just seems odd that both sides went out..
Old Jun 27, 2012 | 09:37 PM
id say u have a connection issue. a relay harness stops flickering by giving a constant voltage from the battery to the relay harness, rather than going through the harness to the balast
Old Jun 27, 2012 | 09:41 PM
okay so not using a relay harness is not the problem its either a connection or a bulb issue?
Solaris99
28
Mar 15, 2017 01:22 PM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
Bohb
Sep 27, 2015 09:11 PM
