HID kit HELP!!!
Old Sep 11, 2010 | 06:16 PM
cobaltiC's Avatar
Exclamation HID kit HELP!!!
Its getting dark soon and I need to get this done before dark since I dont have a garage advice ASAP would be great!
I've installed mostly everything from my HID kit the only thing im having trouble with is where to connect the + wire??? I have my - wire grounded and ive seen the + wire being connected to the fuse box post but the end will not fit over the post!!
Im stuck and have no idea what to do.. where else could to connect the + wire to??
Thanks
Old Sep 11, 2010 | 06:27 PM
ChevyRockstar's Avatar
you can unscrew that post then place the wire below, then tighten it back..
Old Sep 11, 2010 | 06:28 PM
08G5GT2.4L's Avatar
Use a 10mm wrench and undo the post, slide ring onto stud then re-install post.
Old Sep 11, 2010 | 07:09 PM
cobaltiC's Avatar
Sorry i should have clarified that.. i did unscrew it but the wires "o" ring was not large enough to fit under the post so i ended up cutting it a little and widining...still having trouble though the lights wont even turn on I dont know where I messed up..til tomorrow i guess
Old Sep 11, 2010 | 09:09 PM
DFZ24's Avatar
ok so you connected everything; ground, ballasts, positive battery and power source?
Old Sep 12, 2010 | 09:02 AM
cobaltiC's Avatar
I believe so.. im going to try it here soon and see how it goes ill start from scratch to make sure im not missing anything
the kit is 9007 bi-xenon and came with 2 ballasts, 2 bulbs, a relay harness and another harness which I dont know if I use that, the relay harness, or both any ideas?
Heres a pic of the "other harness".. i think? Hope this helps
Anyone know what the cube is? where it goes?
Old Sep 12, 2010 | 10:32 AM
TommyP's Avatar
AWD > FWD
the cube is the relay. Put it somewhere in the ENGINE BAY. it will get ruined if it gets wet
Old Sep 12, 2010 | 11:12 AM
cobaltiC's Avatar
does the relay hook up to the fuse box post? or does the red wire only go on the post
Old Sep 12, 2010 | 11:15 AM
kidcrash603's Avatar
BUY HID's
Seriously dude? Everyone's willing to help, but I'm sure your kit came with instructions. Did you read ANY of them?
Everything you need should be on our installation pages, including pictures.
Old Sep 12, 2010 | 11:16 AM
TommyP's Avatar
AWD > FWD
no, only the red wire hooks up to the post. That metal ring is a mounting point on the relay if you wanna screw it into something.
Old Sep 12, 2010 | 11:26 AM
cobaltiC's Avatar
Originally Posted by kidcrash603
BUY HID's
the instructions are not as easy as you think infact they're complicated as hell..and i'll admit i dont know much about this so any advice gets me that much closer.
one last question do you use the relay harness along with the basic harness that comes with the kit?
thanks
Old Sep 12, 2010 | 12:27 PM
cobaltiC's Avatar
UPDATE: everything is installed.. turned the car on and the lights did not come on but when I held the lever for "flashing the high-beams" back, the lights turned on and that was the only way they would turn on. Also, when you turn the high beams on by pushing the lever ahead, the lights don't turn on either and the high beam light on the dash dislplay does not appear like it should.
What am I doing wrong?
EDIT: only the right bulb turns on while doing that, no action in the left bulb
Old Sep 12, 2010 | 05:25 PM
DFZ24's Avatar
same problem as i did and some others,
the wires are place in the wrong slots.
change bulbs side if one turns on and another doesn't. happened to me. i even had to change ballasts from side to side.
Almost same problem here
dennis69
Oct 20, 2015 04:49 PM
thewafflesareburnt
Sep 30, 2015 02:29 AM
Sep 28, 2015 12:51 PM
metroplex
Sep 27, 2015 07:48 AM
