hid problem
Old Nov 29, 2010 | 12:59 AM
NOLAGSS's Avatar
hid problem
so i bought a set of gen 2 headlights with 6k hids from ddm (not confirmed) any way before this i had bi xenon hids that worked perfectly with no problems. after swapping my headlights leaving my zentec ballast in i have headlights that as i say dance. the light beam will moved left to right rapidly. i figured it was because i didn't have a relay so i installed a relay and i still have the same problem and i know its not my ballast because they worked fine with my other bulbs. im wondering if because my projectors are aimed to high (will be fixed tomorrow) if its possible that my bulb may be touching the projector. or i may have bad bulbs idk any input or experience with this would be appreciated.
Old Nov 29, 2010 | 01:01 AM
redcobalt07's Avatar
maybe you should use the proper ballast
Old Nov 29, 2010 | 01:14 AM
NOLAGSS's Avatar
its not the ballast as stated already the ballast worked fine with my other bulbs and ddm.s website even states there bulbs work with any ballast.
Old Nov 29, 2010 | 01:20 AM
TommyP's Avatar
AWD > FWD
So wait you mean that one light will come on then it will shut off and the other will come on? Check all your connections, your ground on the relay, and bulb alignment. If not that, get new ballasts. It may he that the ballasts are made specifically for bixenon bulbs, despite what DDM says, they've been wrong before.
Old Nov 29, 2010 | 01:35 AM
NOLAGSS's Avatar
no they both come on all the time its just one of the beams of light move side to side like it wiggles. and the ballast are the same as single beam kits the relay kit is what is different i suppose tomorrow ill check to see the bulb is actual in secure and aim the correctly if that dont help im going to hologen bulbs.
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
