hid problems
Old Jan 26, 2008 | 11:30 PM
hoosierguy4life's Avatar
hid problems
i finally got my xenon 8000k hid kit in the mail yesterday. i installed the kit to find that my highs dont work. lows look great but no high. im looking at getting projectors soon but would like to get the problem fixed now so it will be an easy swap. also, do i need to leave the daytime running lamp fuse in the spot marked or will it ruin the lights by leaving it in there
Old Jan 26, 2008 | 11:32 PM
an0malous's Avatar
You realise HIDs dont come with highbeams right?
the only way to have highbeams is to buy a "bi-xenon" hid kit, or use proper HID projectors with a moving cutoff shroud.
and it wont be an easy swap to projectors, as they use a different bulb to the stock headlights.
No offence my friend, but it sounds like you needed to do a little more reading before you bought HIDs
Old Jan 26, 2008 | 11:33 PM
anthonyS88's Avatar
you probably got a low beam only kit
Old Jan 26, 2008 | 11:58 PM
i bought the bi xenon kit and i know for sure. got the ballest and harness installed but nothing but lows
they only sent me one harness, it that right. cuz on the passenger side where the stock headlight harness is(light blue), its just open so the curcuit isnt complete. is there something that goes over that
Last edited by hoosierguy4life; Jan 26, 2008 at 11:59 PM. Reason: Automerged Doublepost
Old Jan 26, 2008 | 11:59 PM
anthonyS88's Avatar
i dunno, i have never effed with dual beam hid kits. just do a retrofit and call it a day
Old Jan 27, 2008 | 12:16 AM
killah_thug08's Avatar
only way you can tell if you have a bi-exnon hid kit is either the bulb is motorized which you can tell by the bottom because it does not look like a reg bulb and second if there is another small bulb beside the long big 1, in other words 2 bulbs
Old Jan 27, 2008 | 12:53 AM
thats exactly what i got. but i still cant figure why i dont have my highs. the fuses are fine unless im supposed to take something out since its an 07
Old Aug 24, 2009 | 08:10 PM
SchmidtUSAF's Avatar
same problem with my setup...bi-xenon no highs. Did you find a solution??
Old Jul 26, 2010 | 09:11 PM
trentonwayne's Avatar
Same problem also. No Highs, but lows with a Philips Bi xenon kit.
Old Sep 13, 2010 | 01:53 AM
Dims but no highs?
Try this forum. https://www.cobaltss.net/forums/2-4l...odules-221007/
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
