HIDs in 2007 (low beam is DRL)
Old Jan 7, 2009 | 01:31 PM
RedEcotecSS's Avatar
I have the 1st gen projectors and I am considering getting HIDs sometime soon. I have a question tho, would the HID be on all the time as my DRL? or would the HID disable my DRLs? Not sure if this has bee answered yet or not but couldnt find any answers. Thanks for any input.
Old Jan 7, 2009 | 01:44 PM
LiL RoB's Avatar
i believe the drls work off of the high beam circuit not the low, also adding hid will not disable drls unless you wire in a seperate circuit
Old Jan 7, 2009 | 01:46 PM
i got to looking at my projectors and when my DRLs are on, it's the same bulb as my lows..
Old Jan 7, 2009 | 01:48 PM
DoubleLP's Avatar
You have to take the DRL fuse out of the fuse box under the hood when you install HID's. The DRL's send a lower voltage and that will screw up the HID ballasts/bulbs really fast.
Old Jan 7, 2009 | 01:53 PM
cobalt blue's Avatar
X2, I have the 1st Gen projectors with HID's and I had that problem,like DoubleLP said if you take out the DRL fuse you avoid having future ballast issues. Also what Im about to say, alot of guys here will not agree but.....You may also want to consider installing a relay harness into the headlamps to avoid having the typical pass side lamp not firing, I had that issue as well and as soon as I installed the rellay and pulled that drl fuse, all my problems went away. JMO.
LiL RoB's Avatar
k then your hid's would be on on drl mode, the only way i can see you being able to make it work is to swith the wiring around with the bulbs to where your hid lows are on the highs circuit and the highs on the lows circuit, this means your brights will now have the drls, its much easier to just disable them with the switch
Old Jan 7, 2009 | 01:54 PM
DoubleLP's Avatar
That is pretty hard to do because it is a plug and play type headlight and you would have to ruin the OEM plug for the headlights. It is just easier to pull the DRL fuse, and if you want DRL's still just turn on your headlights!
Old Jan 7, 2009 | 01:56 PM
No as long as your headlamps have the factory plugs on them you just plug them into the same socket you would the stockers, DRL is a competely different circuit, all you have to do is removed the fuse and you will be good.
Old Jan 7, 2009 | 02:04 PM
LiL RoB's Avatar
True Drl fuse is in a different circuit and just provides 12v comanded by the bcm so removing the fuse is the best alternative
Old Jan 7, 2009 | 02:07 PM
Exactly. Before I did it I think I went through like 2 ballasts, it drove me crazy, so when I was told to pull the fuse that problem stopped but I had a continual problem with the pass side lamp not firing, so I bought a relay harness and installed it now my lights work problem free.
Old Jan 7, 2009 | 02:19 PM
shitty.. i like my DRLs
Old Jan 7, 2009 | 02:52 PM
DoubleLP's Avatar
Just hit your fog lamp button and then your fogs will be on and act as your DRL's.
Old Jan 7, 2009 | 07:46 PM
n0xid's Avatar
Been thinking about something, would it be possible to just install a switch inline with the light sensor in the dash?
Old Jan 7, 2009 | 08:46 PM
NCC-2000's Avatar
Pulling the DRL fuse was one of the first things I did on my 07, never had any issues after I installed my projectors and HIDs.
Old Jan 7, 2009 | 09:46 PM
liljone's Avatar
A week after I got my hid installed into my 2007 the DRL fuse blew and now the DRL is fully disabled and they still come on with auto lights at night. Lucked out I guess but YES they do stay on unless you remove or blow the DRL fuse w/e comes 1st.
Old Mar 2, 2009 | 11:24 AM
cobalt man's Avatar
hey guys is this the same for a 06??? if so where is that fuse cuz i dont think mine was took out because well i still have driving lights and i hate them
Old Mar 21, 2009 | 06:04 PM
2007victoryred's Avatar
Does anyone have a pic of what fuse it is? Also is there any way to just make the parking lights the drl's?
Old Mar 21, 2009 | 07:15 PM
NCC-2000's Avatar
The inside of the fusebox tells you what fuse is for what circuit.
Old Mar 21, 2009 | 07:48 PM
stage2cobaltss's Avatar
no no no... if u go with 3bspec on here u can get the option for 10 bucks more and its a little black box.. IT WILL KEEP UR DRL !! their awesome hid's also !
also no fuses need to be touched or anything.. its all plug and play i also have gen 1 projectors
Last edited by stage2cobaltss; Mar 21, 2009 at 07:48 PM. Reason: Automerged Doublepost
Old Mar 21, 2009 | 08:46 PM
so what lights are the drl's after you install that box?
Old Mar 23, 2009 | 09:46 AM
yup
yes if ur car has drls factory... u get a little black box along with the kit and it just hooks up and it will keep ur headlights still drl. kit is so easy to use btw if u have any questions just ask.. i installed the custom blue head and fog light kit on my car also used the drl box to keep my headlights on drl
RaginChopsuey
Oct 27, 2015 01:27 PM
HEATON
Oct 16, 2015 07:21 PM
agentirons
Oct 16, 2015 02:11 AM
DANRICKARD
Oct 1, 2015 12:08 AM
Sep 28, 2015 12:51 PM
