HIDS from buyhids
You do realize that a single kit comes with two bulbs and two ballast along with a single relay which will wire both of them, so you don't have to order 2 kits.
Some people missed what i posted. DDM Bi-Xenon is cheaper for a reason. Its not a REAL Bi-Xenon setup. There bulbs go in/out of the socket producing a very small increase in output. Our Bi-Xenon kits, the bulbs tilt giving you a true high beam pattern. There is a big difference and unless you've tried both, it will be hard to know what im talking about unless you see the difference.
The thing is, people who spend more money are always gonna bash the cheaper alternatives because its their way of justifying the money they spent. Me peraonally, I'm all about the deals. When I want any product, I always look for the alternatives to see if thwy are any cheaoer and how they stack up against the more expensive counterparts. Hell I've used ebay parts a lot including ebay turbos and have had good luck with all the parta I've bought.
On the subject of hids, any of them are gonna be better then stock lighting so who reallt cates what the price is? If you can get them cheaper then go for it.
Im gonna call bullshit on the "REAL bi-xenon" part here.....in/out versus up/down, really? They are all just bandaids/gimmicks for the fact that HID bulbs arent meant to be used in and dont work properly in halogen reflectors. The bulb tilting is going to move the HID arc in an arcing motion, that right there gives you the wrong light spread not even taking into consideration the HID arc itself is the wrong "shape"
Also remember that not all bulbs have there filaments arranged the same way, so while BHs up/down may be "better" for a 9007 bulb, its gonna be worse for a 9004, which is where DDM style in out would in theory work better, except for again, the HID is horribly misaligned to start in transverse bulbs and nothing will help those.
But the whole thing about these moving bulbs being better one way or the other just proves my point, its largely crap and unfortunately the guys selling dont know (or care) any better.
Not picking on you personally Mkulrey, its just I get sick and tired of all these gimmicky moving bulbs and other bullshit....which by the way this would probably be the "true best" solution for 9007s if their is such a thing.
Thanks maven, your pic proves my point, Our bulb tilts which puts it in that location of the second bulb on your picture. There is no in and out motion like all other kits. If someone wants to send me a DDM "Bi-Xenon" bulb i can do the test
PLEASE POST PICS OR VIDS!!! I want to see how they work. and Im not going to buy them so dont just say order them, I want to know if I should recommend them to the Non-retro worthy.
Ahhh, but there is:
Pro - no moving parts, no chance of the bulb getting stuck on high or low position.
Con - need 2 ballasts per side.
Con - the high beam source will not be located in the original relationship with the reflector....but this may actually provide a little wider spread on the high beam.
Con - the low beam will still glare like a ****
