hood question
Old Nov 20, 2010 | 02:04 PM
DEZZIE41's Avatar
hood question
got a cf hood with 2 vents in in what would u recomened to use to cover them for the winter months so no snow get in there....aslo what to use for a hood prop so i dont twist it
Old Nov 20, 2010 | 02:09 PM
jsscooby's Avatar
SS hood liner. not really certain if it will attach to a CF hood though.
Old Nov 20, 2010 | 02:10 PM
DEZZIE41's Avatar
mmm ya really i thought maybe tape the under side or somethign
Old Nov 20, 2010 | 02:11 PM
heathkidder's Avatar
use sum 3m double sided tape for the hood liner. maybe alil duck tape just incase.
Old Nov 20, 2010 | 02:12 PM
jsscooby's Avatar
ah i gotcha. i was going for something clean. some gorilla duct tape might hold. although you might be left with some residue when you take it off later on. then again, there is goo gone.
Old Nov 20, 2010 | 02:13 PM
yep goo gone will solve that last issue
Old Nov 20, 2010 | 02:14 PM
DEZZIE41's Avatar
i would be applying it on the under side so dont matter if there is resadu...now what can i use for a prop to keep hood oprn without it bending and what not
Old Nov 20, 2010 | 02:38 PM
b00sted06ss's Avatar
im not to sure, maybe you could go to a shop and have them fabricate some pieces to fit out of some material
Old Nov 20, 2010 | 05:07 PM
DEZZIE41's Avatar
bump for more ideas on what ot use to prop my hood so not to damage it
Old Nov 20, 2010 | 06:49 PM
DEZZIE41's Avatar
Old Nov 20, 2010 | 07:36 PM
DEZZIE41's Avatar
Old Nov 20, 2010 | 08:10 PM
biniecki's Avatar
My vented CF hood came with a fiberglass insert that is removable. I usually only remove it during shows. Insert funnels the water to exit above the grille. As for a hood prop I usually just use some sort of pole. Anything from a 2x4 to a broomstick to a pool stick. I did see someone use a small adjustable rod that resembled a curtain or shower curtain rod before. A cheap way cover your vents would be to just tape some plastic to the underside of the hood around the vents.
Old Nov 20, 2010 | 08:14 PM
DEZZIE41's Avatar
ok kool cause snow is coming lol...one i need a pole for each side to keep the hood from flexing
Old Nov 20, 2010 | 08:17 PM
biniecki's Avatar
I just use one pole and place it under the latch
Old Nov 20, 2010 | 08:19 PM
DEZZIE41's Avatar
thats wut i thought lol...i got the vis invader hood with a candy apple yellow clear coat on it with a small tinge of gold flake
Old Nov 21, 2010 | 09:38 AM
kenhebe's Avatar
Goo gone should not be used on automotive paint or gelcoat. It is too abrasive.
Old Nov 21, 2010 | 10:24 AM
BlueBalt1113's Avatar
if you have your old hood put it back on cause the carbon fiber can spider crack real easy in the winter cause of temp change
Old Nov 21, 2010 | 11:44 AM
DEZZIE41's Avatar
i dont havd my stock hood no more does anyon eleaving there cf hood on in the winter time//
Old Nov 21, 2010 | 06:19 PM
biniecki's Avatar
I leave mine on all year round. However the car is parked during the winter months. It stays outside all year round until I get a house with a garage lol
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
