hood question
hood question
got a cf hood with 2 vents in in what would u recomened to use to cover them for the winter months so no snow get in there....aslo what to use for a hood prop so i dont twist it
My vented CF hood came with a fiberglass insert that is removable. I usually only remove it during shows. Insert funnels the water to exit above the grille. As for a hood prop I usually just use some sort of pole. Anything from a 2x4 to a broomstick to a pool stick. I did see someone use a small adjustable rod that resembled a curtain or shower curtain rod before. A cheap way cover your vents would be to just tape some plastic to the underside of the hood around the vents.
Iceberg
Sep 29, 2015 12:33 PM
