How To Change Your Halo's!
Old Feb 7, 2008 | 03:01 PM
nramlow2006's Avatar
Originally Posted by cobaltcruisin
I did this a few months ago.. and it sucks.
I'd much rather install a full exhaust on a car then to do the led change again. My hands shake too much.
sorry about that. my best friend has a problem with his nerv's and he has jittery hands. he builds computers for a living..
its amazing.
Old Feb 7, 2008 | 03:58 PM
NOS2006's Avatar
The stockers are pretty damn bright in those pics. I tried to solder in yellow ones before I installed my halos, and the solder or LEDs didn't work so only 2 of 4 halos work, and not very bright. Can't wait for your other pics.
Old Feb 7, 2008 | 04:05 PM
Co|3aLt $$'s Avatar
so will these make the halo's brighter? cause I think you could imagine there would be a light there and it would be brighter than the crap they came with.
Old Feb 7, 2008 | 04:08 PM
well i used 5mm bulbs and the ones it comes with are 3mm bulbs this is a larger bulb. more area in the bulb makes a wider light path..
in theory
Old Feb 7, 2008 | 04:09 PM
06_SS_S/C's Avatar
Damn that looks a lot easier than soldering which i already did lol. I've been wanting to try red ones, maybe I will order some of these and see how they come out.
Old Feb 7, 2008 | 04:11 PM
Co|3aLt $$'s Avatar
I have a boat load of 3mm blue LED's which are SUPER bright...but they are also very narrow in the light pattern they put out... so we'll just hafta experiment i guess
yeah im going to actually take these ones out and install orange ones provided they turn out bright enough. will c
Old Feb 21, 2008 | 03:29 AM
06_SS_S/C's Avatar
Don't **** with my car, it's pissed!
Old Feb 21, 2008 | 03:48 AM
REIGN SS's Avatar
Original Hayden Fanatic
You have to look at the Luminous Intensity of the color you are going to order... Higher # = brighter... the 5mm are brighter, and fit so I would use those
Old Feb 25, 2008 | 10:41 AM
boricua s/c ss.'s Avatar
i have a question how do u open up the lights to put the new halo lights(led)in. dont they have some sort of glue or rubber that is stuck on. I need to replace by halos, i took of the screws but it still dosent open.
Old Feb 25, 2008 | 10:47 AM
  #36
JPizzle's Avatar
There is a rubber grommet on the bottom, that you have to "pull out." After you pull that out, you pull out the LED's.
Here is a how-to: https://www.cobaltss.net/forums/how-guide-43/how-replace-burnt-out-halo-68874/
turbochargedss2012
Sep 20, 2023 12:17 PM
importkiller
Sep 30, 2015 07:18 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
jmelton327
Sep 26, 2015 10:04 PM
