How do you remove...
Its not that hard. I cant remember exactly but you remove the liner under the trunk lid by removing all the push pins. You probably already know that.lol. Anyhow there is going to be a rod going to the lock assembly that is attached to a plastic clip that you just push downward and it will unclip followed by I believe there may be a couple 10mm bolts holding the housing and mabye a clip or something. Sorry for not remembering exactly but once you have that panel removed just take a light and have a good look inside there and you will be able to see whats going on. It really isnt that hard though.
ok for rhe trunk lock theres a big metal clip pull it otu and the lock just falls out and the spoiler heat up the underside of the spoiler with a hair dryer and remove the 2 bolts on each side and start to pull and it will eventuallly come out
how do i re-install the lock assembly with the trunk being shaved? lol the key hole on the outside won;t go through the trunk
bump before i go down to mothers in easton, pa for cinco de mayo
2 dollar coronas WOOT!
Last edited by BlackSSNick; May 5, 2009 at 09:07 PM. Reason: Automerged Doublepost
from what i remember it was just a tight ass clip on the lock cylinder, i took that out and the 3 bolts holding the electric lock assembly out, took out the lock, and replaced the electric assembly without the lock cylinder. trunk popper still works
