how to remove the seat belt rings next to the head rest
Old Jul 3, 2006 | 01:23 PM
slick54's Avatar
Question how to remove the seat belt rings next to the head rest
i want to know how to remove the head rest ring were the seat belt goes trough because my seat covers wont fit right unless i remove it
Old Jul 5, 2006 | 01:10 AM
Florida 76's Avatar
dremel
Old Jul 5, 2006 | 01:20 AM
JimmiLS05's Avatar
Yea, the only way I've seen is to cut it
Old Jul 5, 2006 | 02:42 AM
EetMorJello's Avatar
Yeah, I had to cut mine too.
Old Jul 19, 2006 | 05:35 PM
Sargeant_002's Avatar
You guys don't have to cut them off...you can actually remove them...we did it in PrincessNee's car...I can explain it if needed...
Brian-
Old Jul 19, 2006 | 05:40 PM
xspyder85x's Avatar
its needed
Old Jul 21, 2006 | 08:44 AM
REIGN SS's Avatar
Original Hayden Fanatic
Check out the HOW:TO- REMOVE SEATBELT HOLDER
Old Mar 7, 2007 | 06:21 PM
stvn's Avatar
all you have to do is remove the head rest and get some pliars and twist off the metal peice that is holding the plastic peice to the hear rest, its really simple, i did it about 10 minutes ago, and it only took about 5 minutes
if you take the plastic peices off, will it void the warrenty?
Old Mar 7, 2007 | 06:25 PM
calchr2's Avatar
like stated above, you do not have to cut the plastic to get it off. you can remove the headrest then you have to remove the metal ring that holds the plastic piece onto the headrest arms.
lift the headrest all the way up. theres a plastic piece on one of the posts, remove that and theres a hole that you have to push in a spring to release the post from the seat back. when it is released pull the headrest out and remove the metal retaining rings that hold the plastic piece on and reinstall. when i did mine, i just turned the plastic seatbelt holder(if thats what you want to call it) around, so it is facing up and back.
not much of a change but it is more comfortable to sit, if your taller than 6 feet, like i am.
not sure if it will void the warrenty. if theyre not theyre it makes grabbing the seatbelt a pain.
DarrenGC
Dec 24, 2021 01:55 PM
HEATON
Oct 16, 2015 07:21 PM
justinchinn
Oct 2, 2015 12:18 PM
cw383
Sep 30, 2015 12:41 AM
