how to remove stock shifter knob???
Old Apr 7, 2007 | 11:59 AM
BlueBomber07's Avatar
how do you remove the stock shifter knob???
Old Apr 7, 2007 | 12:04 PM
SS33's Avatar
If you have the 5 spd, there will be a little cap on top (w/ the shift pattern that must be removed) and a screw underneath that that holds the knob to the shaft. After removing that screw just pull like hell and twist and it will come off eventually.
If you have an auto than I'm not sure.
But most that respond will tell you to search. Head to the How-To forum,,, you'll likely find what you need, or at least be ready to ask a more specific question.
Hope that helps
Old Apr 7, 2007 | 12:09 PM
Killjoy32's Avatar
dont the Ls versions has a full shitty plastic shifter, its so shitty. Its 100% plastic!
Old Apr 7, 2007 | 12:16 PM
BMWM51969's Avatar
at least i dont need to pull up reverse. lol. but yes its a plastic shitty shifter. 100% ****.
Old Apr 7, 2007 | 12:35 PM
rickyw's Avatar
lol theres nothing wrong with pulling something up to go reverse. its fun when ppl get in and try to put it in reverse and they cant
Old Apr 7, 2007 | 05:31 PM
cea2488's Avatar
I don't know if it's the same for 2007, but for my 05 LS...
1. Twist the boot clockwise (I think) until it unclips and push it down so you can see the steel rod.
2. Pull up.
I did it about 4 months ago, so I think that's all there was to it... but I might be forgetting something. Again, that's for my 2005 LS, so I don't know if things have changed. I thought that the torx screw was only on the SS/SC?
Old Apr 7, 2007 | 06:53 PM
cobaltkid32's Avatar
yeha thats all there is...unclip and pull up comes right off did it about 2 weeks ago when i put my new sparco knob on
Old Apr 7, 2007 | 07:22 PM
StealthSS's Avatar
the reverse safety is pointless anyways. you can take it off and it still wont go into reverse "by accident"... its there to make you feel better so you wont worry about throwing it in reverse when going to 4th, even though you really can't without trying to anyways. I took the safety thing off my cavalier when i put a new knob in it. I'll probably do the same with the cobalt.
Old Apr 8, 2007 | 02:16 PM
thanks for the info fellas!!!
Old Apr 8, 2007 | 02:20 PM
Goin2Fast06's Avatar
yea our shift knobs suck! When I was leaving work the other day I went to shift into 2nd gear the damn thing flew off and hit me in the forehead. the little spring shot off and I had to drive like 5 miles with just the stick.
Oct 21, 2015 11:57 PM
footballplaya3k
Sep 30, 2015 09:39 PM
2009blackSS
Sep 30, 2015 05:57 PM
Sep 27, 2015 08:53 PM
