HVAC LEDs
Old Mar 24, 2013 | 04:59 PM
derekhollister's Avatar
HVAC LEDs
ok so im trying to change my HVAC lights and its not comming out right i put it in the car and it doesnt even light the whole thing up... so what am i doing wrong i changed the bulb to the exact same spots as the old ones.
here is a picture to kinda show what i have goin on
Old Mar 24, 2013 | 05:03 PM
are you sure you have the correct posts corrected with the new leds? the sides do matter with polarization or w/e its called
Old Mar 24, 2013 | 05:06 PM
ya the lights lighting up bur when u hook it up and turn the lights on its not coloring up the things its suppose to if ur understand what im saying
Old Mar 24, 2013 | 05:12 PM
like with the cover on u cant see the light
cuebalt's Avatar
U need more then just 1 LED
Old Mar 24, 2013 | 05:13 PM
how many per one spot should i put
Old Mar 24, 2013 | 05:16 PM
cuebalt's Avatar
Actually sorry i waz thinking of the guage cluster, just try and aim ur leds better if u can and try to disperse the light a bit
Old Mar 24, 2013 | 05:17 PM
how would i do that
Old Mar 24, 2013 | 05:20 PM
can someone post a pic of their HVAC LEDs
Old Mar 24, 2013 | 05:27 PM
cuebalt's Avatar
Cant quite remember how i did mine, hopefully someone else chimes in, otherwise i'll take a pic of mine later today. Check out this thread though, info should be somewere in it. https://www.cobaltss.net/forums/how-...nfo%2A-261124/
Old Mar 24, 2013 | 05:37 PM
C_A_D88's Avatar
Use brighter leds
Old Mar 24, 2013 | 05:39 PM
C_A_D88's Avatar
U only Need one per spot u just need ones that actually put out
Old Mar 24, 2013 | 07:02 PM
they put out just fine for my gauge cluster
Old Mar 24, 2013 | 08:11 PM
where should i get my LEDs from? i perfer pure white ones
Old Mar 24, 2013 | 08:28 PM
zerosk8ter83's Avatar
the leds need to shine outward not straight up.Cover the top part of the led so they shine down ward. I use tape.
Old Mar 24, 2013 | 08:41 PM
what kind of tape did u use
Old Mar 24, 2013 | 11:45 PM
cuebalt's Avatar
^that was what i did, just use a tape that the light can still shine through but also gets dispersed across the board, like painters tape or something
Old Mar 24, 2013 | 11:51 PM
xxenjoi11's Avatar
thats what she said
Old Mar 25, 2013 | 02:34 PM
i used clear tape and that didnt work
Old Mar 25, 2013 | 02:44 PM
ofcourse it didnt use electric tape or duct tape
C_A_D88's Avatar
If u get normal LEDs, sand the top of the led off so it's flat.(use 600)
And then sand all around the outside to make it a diffused led, no tape needed
Old Apr 4, 2013 | 06:29 PM
Squints's Avatar
black electrical tape will do just fine. you just need a big enough piece to cover the top of the bulb and you will be fine. look at the link on my sig thats what i did for a member on here.
Old May 6, 2013 | 02:21 AM
Crav3's Avatar
I installed 2 leds on each and it lights up but not as bright as I wanted to. Tried sanding them too. But not really doing much. Put tape on top and it did dispurse the light around but still not as bright and the bottom buttons are not really lighting up
chefhhr
Oct 26, 2015 10:36 PM
How to Guide
57
Oct 15, 2015 11:56 AM
Supercharged06SS
Oct 5, 2015 09:13 PM
dieGone
Sep 23, 2015 10:20 AM
jonnycat
Sep 19, 2015 12:58 PM
