key fob
Old Jan 3, 2012 | 03:22 PM
rectorc08's Avatar
sub'd for results.
Old Jan 23, 2012 | 10:44 PM
deereboy4320's Avatar
well it arrived today and it is bigger than I thought it would be. I attached some photos to show how big it really is. will be getting it programmed and the key cut at the end of the week.
Old Jan 23, 2012 | 10:48 PM
here is it with the key out.
Old Jan 23, 2012 | 10:57 PM
getwicked's Avatar
The "chip" in the key is a transponder that tells your car that the key being used is right and not cut to steal your car which can be done by vin. They have to be programmed to your car's coding.
Programming procedure for our cars keys:
1) start car with programmed/working key.
2) wait for all your check lights to go out on your cluster
3) turn car off and immediately (within 3 or so seconds) start car with 2nd "new key"
4) wait for all lights to go out on cluster again
5) wait 30 seconds for ignition module to "reboot"
6) start key with "NEW KEY" to make sure it worked.
I AM IN NO WAY RESPONSIBLE FOR ANY HARM/OR MISS-INSTALLATION YOU DO TO YOUR CAR.
This is how I learned my spares and how I was taught to learn our GM transponder keys.
Old Jan 24, 2012 | 12:07 PM
well thank you this should come in handy after it is cut, assuming the dealer doesn't do it for me.
Old Jan 24, 2012 | 11:11 PM
getwicked's Avatar
They'll usually charge more than just the key cut to program it.
Old Jan 25, 2012 | 12:23 PM
MoJoJoSSsc03's Avatar
ok sooooo now i see!!! lol... my bad.. i didn realize you had the new switch blade keys.. i got the older seperate FOB and KEY.. oh well.. i hope yours goes well then..
Old Jan 25, 2012 | 04:49 PM
Rubberdude88's Avatar
Great write up!!! Hope that deerboy gives an update as to if this worked or not.
Old Feb 3, 2012 | 01:51 PM
JBMark33's Avatar
I am thinking of doing this. I was really hoping to get a 4-button 2012 Chevy Equinox key because it appears to be of better quality than the ikeyless key fob, but the dealership the Equinox key wouldn't fit due to the size of the metal key itself.
Any updates on how it's working?
Old Feb 4, 2012 | 01:51 AM
getwicked's Avatar
The equinox key is a different style. The "switchblade" key he's talking about it still a factory style key and fob, just in a different molding to make it a switchblade style.
The equinox is a completely different style fob and key. It's reminiscent of a BMW key. It has a bar with the pattern cut into the side of the key instead of on the edges. Even if you could get the key part to work, good luck getting it programmed. It's not the same transponder type and is actually a high tech computer in and of itself.
Old Feb 5, 2012 | 04:05 PM
  #36
the key fob they gave me worked but they were unable to cut the key. I have to detach the key from the fob for them to cut it. will let you know when I get that cut if it works.
Old Aug 18, 2012 | 10:45 PM
  #37
thatkid101's Avatar
well....did it work!?!?!? mine is on the way!
Old Aug 18, 2012 | 10:57 PM
  #38
06CobaltSS635SC's Avatar
ours has a chip? what year did they start putting that in? do you mean the key? I dont think their is a chip in our keys, at least not in my 06 one.
2006+ Cobalt's keys have chips. To tell if your key has a chip look at your key and where the plastic grip of key meets key it self if there is a plus (+) sign in a circle on each side of key it has a chip in it. As seen in image below.
Old Sep 12, 2012 | 09:27 PM
  #39
thatkid101's Avatar
well i got mine and had the dealer cute it they told me it will not work blah blah blah got home programmed it and it worked!!!
Old Sep 13, 2012 | 11:06 AM
  #40
Dipped_Cobalt's Avatar
you had to remove the key to get it cut?
Old Sep 13, 2012 | 12:19 PM
  #41
JBMark33's Avatar
Which fob did you buy and how did you get the key cut?
satisfied
Oct 19, 2015 12:35 AM
Extreme Dimensions
Sep 24, 2015 07:51 PM
Shane H
Sep 20, 2015 11:56 AM
Gugi96
Sep 15, 2015 12:24 AM
jthwjde
Sep 7, 2015 09:24 AM
