lambo door kit
Old Mar 4, 2008 | 06:23 AM
BlackBaltLT's Avatar
lambo door kit
My question for the people who have the door kit, how long did it take you to put on. Its a bolt on kit not just a universal. Other question I have is how do you think it would look on my balt? Of course I will have other mods done too.
Old Mar 4, 2008 | 06:32 AM
BOOSSTED 06's Avatar
im speaking from kits Ive helped install on other cars. Most times there is some trimming required just inside the fender, you will never see it outside but it is so the hinge can swinge freely and un-obstructed
Old Mar 4, 2008 | 06:33 AM
skymynx's Avatar
i actually just ordered mine this morning from vertical doors. for 950 shipped.
Old Mar 4, 2008 | 10:56 AM
TSSDISCO's Avatar
I have the jt autosports lambo kit and it is a bolt-on kit but you need to shave the rolled edge of the fenders down to the edge.
You need to take off the L bracket located in the middle of the fender as it interferes with the swing arm. I used a drill to drill out the spot welds a flathead and hammer to chisel off the bracket.
It was my first time ever installing a door kit so the right side took a while to adjust. And figure out how to get slack in the wiring harness.
All in all it took me about 10 hours to install most of the time spent was figuring out how to take the doors apart. Mounting the kit and adjusting the allen bolts (fine trim adjustments) Was pretty easy. You need a friend to help you hold the door.
So when they say this is a bolt-on kit with no welding or cutting that is not true at all. Maybe that description has to do with mounting the kit which is true. It's just everthing else you got to cut up.
Old Mar 4, 2008 | 11:03 AM
sick06cobalt's Avatar
1. You should drop your car....
2. Most kits as said ^^ do need to have some kind of work to get them to fit well and correctly.. ect...
3. Autoloc, Vertical doors, and Jt are all good companies for the doors.
4. I thinkk your car will look good with it once its dropped... either do coilovers or springs...
Old Mar 4, 2008 | 11:06 AM
Coblt ss super's Avatar
Well put it this way, if u buy a cheap kit, your gunna get cheap and broken struts or hinges. Then you have the problem on aligning every so often so they fit right.
Old Mar 5, 2008 | 04:20 AM
That kit looks great. so you didnt have to extend the wires? Also thanks for the info about the bracket needing to be removed.
Old Mar 5, 2008 | 08:43 AM
PlaysWitCars's Avatar
Former Cobalt Owner
It took me and cobaltlax13 to do his in about 6 or 7 hours total.
and there is an easy way of extending the wires
Old Mar 5, 2008 | 08:48 AM
Which would be to do?????
Old Mar 5, 2008 | 09:20 AM
Former Cobalt Owner
just pop the wire clips off from the inside of the door to give you enough slack to put the door up
Old Mar 9, 2008 | 01:19 AM
Heres the kit i ordered.
Old Mar 9, 2008 | 01:29 AM
wow that came pretty quick
Old Mar 9, 2008 | 01:33 AM
I ordered it last friday, i was just asking peoples opinions. Also i just bought ss/sc springs to drop it a little.
Old Mar 9, 2008 | 01:37 AM
dude the ss springs wont barely drop it...
Old Mar 9, 2008 | 12:29 PM
It will do about a 1" drop and thats all i can really do with where i have to drive, thats why i eventually want to get an air bag kit so i can raise and lower it.
Old Mar 24, 2008 | 08:16 PM
Fire_Starter's Avatar
Where did you order them from? Website details please and thank you.
Old Mar 26, 2008 | 11:44 PM
heres a pic.
firestarter if your interested in the kit PM me.
Old Mar 27, 2008 | 02:05 AM
stretch89's Avatar
wow **** looks nice i always wanted lambo doors but i got the ls so it will do no good
i guess i hate to get the ss:/
Old Mar 27, 2008 | 02:11 AM
I would trick out the ls, my friend has one and he is and we have a friend with a lt tricking it out, if you love it do it man I am.
Pm sent btw
Last edited by Fire_Starter; Mar 27, 2008 at 02:11 AM. Reason: Automerged Doublepost
Old Mar 27, 2008 | 02:32 AM
stretch89's Avatar
thanks man but idk if i really want put all this money into my car wen its just an ls ukno but ireally dnt care bout the performance cause im not into the racin uknow. and my car can smoke a tc anyday so im happy with that
Old Mar 27, 2008 | 03:09 PM
mine is just a LT with a SS wing.
Old Mar 27, 2008 | 05:43 PM
skymynx's Avatar
you get yours installed yet. got mine on yesterday. still need to cut the fender lips. but ill be doing that later today
dennis69
Oct 20, 2015 04:49 PM
thewafflesareburnt
Sep 30, 2015 02:29 AM
Sep 28, 2015 12:51 PM
metroplex
Sep 27, 2015 07:48 AM
