LED 3rd Brake light from MPx
The darker color doesn't let as much light through, therefore it doesn't let as much heat through it. Same thing happened when I blacked out my amber lens in my headlights.
Insofar as fabbing up the mounting hardware I used 3m doublesided tape, same tape has been on 2 different cars for a combined mileage of 60k miles.
All in all I'd seriously give this project a half a star out of 10, and that's only because you gotta figure out which wires go where. Get it wrong? No worries nothing burns out or blows up, just swap the wires and finish up.
the MPX one is alot easier as for the impala you have to find the whole housing and than your stuck with a useless housing since you only need the led board from it.
i love my MPX brake light!
this
Last edited by Cobalt08LS; Apr 17, 2011 at 01:41 PM. Reason: Automerged Doublepost
Seems easy enough. The MPx one simply plugs right in. Just saying. And the MPx one will require you to come up with a way to hide the remaining bulb if you're **** about making it perfect like myself. Just saying. Not that either board is better than the other, but they're about the same price and serve the same purpose. There's no need to compare which is better. They each look a little different and each require a wee bit of fab work to make it work or look perfect. Different strokes for different folks.
i like the look of the mpx over the 2 led boards that you have so yeah.
my mpx is bright enough to satisfy me. wouldnt want it any brighter.
