led boost gauge
Old Dec 12, 2007 | 10:45 PM
cobaltss4u2env06's Avatar
led boost gauge
How do you switch out the stock light bulb in the boost gauge to make it led?
Some one has done it but i thought the factory boost gauge was sealed?
This is what it looks like with a led.
https://www.cobaltss.net/gallery/sho...hp?i=24813&c=3
Old Dec 12, 2007 | 10:52 PM
stealthy1ss's Avatar
I thought you couldn't do that as well. If you want answers just pm that person to see what they did.
Old Dec 15, 2007 | 11:05 PM
2006BlackSS/SC's Avatar
i have pm'd him and told him how to do it
if i get me another boost gauage i will do one in blue
the only drawback to doing this is messing up your bazel some next time im going to heat it up and remove it that way if i can
anyways here is how you do it
this is not a how to nor am i responseable for any damage done to your car
you take sole responceability in doing this
your remove your boost guage from the side
then you pry up underneath the silver part of the houseing that holds the lexan cover over the boost suage
then remove it carefully
then remove the black covering and the needle this must be done
then unsolder the stock led's that are white
plug the guage into the socket and use a voltmeter to find the - and positive
once you do that you know what way to put the + of the led i used a resistor even though the stock one diddnt have one on the led cause its a surface mount
in therory u shouldnt have to use a resistor
the only thing about not useing one is that u will blow the resistor or not
then once u have it all figured out solder the - to the - and + to the +
there are 2 led's inside of it
if u want it brighter u can rig something else up
put it all back togather and away you go
again i take no responceability on if you ruin your boost gauage
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
Sep 27, 2015 08:53 PM
