LED Fog Lights
Old Aug 22, 2007 | 06:31 PM
stealthy1ss's Avatar
LED Fog Lights
So I did a little searching on the internet and found these led fog lights. I have HID's and need something to match. Has anyone had any experience with these or something like these and what does everyone think?
http://www.mazda3forums.com/index.php?topic=69935.0
Old Aug 22, 2007 | 06:34 PM
REIGN SS's Avatar
Original Hayden Fanatic
interesting, i wonder how bright they actually are
SilverLSJ's Avatar
they're a sweet looking upgrade, but that thread is originally from february, have you talked to them?? do they still have them? ill gladly be a test subject to see if they're any decent
Old Aug 22, 2007 | 06:37 PM
REIGN SS's Avatar
you might PM mkulrey13 & see if he can get ahold of some for a good price...
Old Aug 22, 2007 | 06:41 PM
Omega_5's Avatar
Ummm... No!
LED's are good for bight accute angle light, or dimmer more dispersed light. Signal lights, park lights and taillights are great to convert to LED, but not driving lights.
LED's have a projection problem over a large angle. Being that driving lights have to light up a large area, you can easily see the problem.
A great example is this -> would any of you guys with projectors rely on the LED's to light up the road for you? I thought not.
Old Aug 22, 2007 | 06:47 PM
laserblue2006's Avatar
Originally Posted by Omega_5
Ummm... No!
well it depends on what you use your fogs for....if you just use them as show lights then you could get these to color match your HID's.....But if you are gonna actually use your fogs for driving in fog and mist then i wouldnt get these....
Old Aug 22, 2007 | 07:27 PM
en0onmai's Avatar
^--exactly. I tried the LED H3 replacements in a set of fogs with no luck, LEDs are crap for light output on fogs but if all u want is color match.. get them.
Old Aug 22, 2007 | 07:42 PM
Jackalope's Avatar
IDK guys have you seen the new LED flashlights? They're bright as ****! These may just work.
Old Aug 22, 2007 | 07:45 PM
ReggaeRampage's Avatar
I'd definitely like to see how these look in person.
Old Aug 22, 2007 | 07:52 PM
SC cobaltss15's Avatar
ummm i definitly agree with jackalope here.. i bet you buck that they are worth it and bright as ****...does anyone have a price or anything?
actually guys if u read that link the guy says i would not rrecommend them for driving lights as you will not get enough light out of them...
Last edited by SC cobaltss15; Aug 22, 2007 at 07:52 PM. Reason: Automerged Doublepost
Old Aug 22, 2007 | 08:44 PM
If you go to the last page someone asked if they were still available a couple days ago and the company said yes. That would be sweet if you were the test subject!
Ummm... No!
I am only using them to help color match my HID's so they are going to be strickly for looks purposes only.
Old Aug 22, 2007 | 10:08 PM
well then these should be perfect for you....and as long as they are for the right bulb size i dont see why they wouldnt work....get 'em and let us know how they turn out....
Old Aug 22, 2007 | 10:57 PM
Renesis's Avatar
why don't you just get regular aftermarket halogens?
I have 7500k nokya artic white and they have that HID blue tint to them!
Old Aug 22, 2007 | 11:23 PM
SilverSS/SC's Avatar
Pretty cool idea . They definately have light cast evenly to reflect off the housing to cast light to the ground . I could see them working much better in a projector style fog over the traditional reflector the Mazda 3 uses . I see they used a "ultralux" LED on the amber version . If they used a ultralux as the top bulb and the surface mounts around the perimeter , I bet it would be as bright on the ground or brighter than our stock halogen in the projector fog light housing . That ultralux led bulb has a 130* viewing angle and is as bright as incandesnt . 1 of those could evenly light an entire taillamp housing if positioned and diffused properly .
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
z28addiction
Sep 28, 2015 12:03 AM
