Led halos - retrofit help
Old Jan 7, 2013 | 10:45 PM
Andrewjw09's Avatar
Hey guys. I'm doing a morimoto mini H1 retrofit. I can't figure out where the LED halos go? Between the shroud and the projector? Or over the shroud? If it goes between.... Where does the wire go? It doesn't seem like there's enough room without bending the **** out of the wire?
Old Jan 7, 2013 | 10:49 PM
kdub1492's Avatar
That honestly ur choice haha. I put min behind the shroud, epoxied it in then tucked the wires out thru the back...
Old Jan 7, 2013 | 10:51 PM
TommyP's Avatar
AWD > FWD
If it's an actual led halo the only place it's likely to actually fit it on top of the shroud. CCFL you could probably fit under but led would most likely be too thick. Also depends on what size they gave you
Old Jan 7, 2013 | 11:13 PM
Andrewjw09's Avatar
It fits. There's more than enough room between the shroud and the projector. It's just the wire where it comes out of the halo is pushed too tightly against the inside of the shroud and I'm afraid it'll damage it because those wires are pretty fragile. I'm thinking about dremeling out a notch there but was just wondering how other people got theirs to fit
Old Jan 8, 2013 | 04:02 PM
Andrewjw09's Avatar
The light will still be visible from inside the shroud, correct? I just think it would look tacky on the outside during the day cuz the rubbery coating that goes over the LEDs is **** yellow
Old Jan 8, 2013 | 04:11 PM
TommyP's Avatar
AWD > FWD
I doubt they will be very visible at all, should be dark enough to hide it.
Old Jan 8, 2013 | 08:27 PM
Andrewjw09's Avatar
But I want the light to be visible... Lol they're halos
Old Jan 8, 2013 | 08:30 PM
Bass_Waves's Avatar
put em on the outside then. use a really thing fish line and tie em up to the projector shrouds.
Old Jan 8, 2013 | 10:42 PM
TommyP's Avatar
AWD > FWD
That would completely defeat the look he's going for.
Old Jan 9, 2013 | 05:09 PM
Andrewjw09's Avatar
Yeah. Not to mention the LED halos are pretty fragile pre-installation and securing it with fishing wire over the top could damage the phosphorous coating
Edit: I did find a solution tho. The halo fits perfectly snug between the projector and the shroud. Didn't even have to glue it
TedSS
101
Apr 25, 2016 10:46 PM
How to Guide
57
Oct 15, 2015 11:56 AM
dieGone
Sep 23, 2015 10:20 AM
jonnycat
Sep 19, 2015 12:58 PM
