LED Install Help
Old Sep 3, 2006 | 12:26 PM
wdsoccer's Avatar
LED Install Help
I just bought a couple of LED neon tubes to put in my car and i want to hook them up to a switch so i dont have to use the crappy cigarette holes to power the neons. so heres the question...how would i wire this so i can run it through a switch that i bought?
Old Sep 3, 2006 | 12:34 PM
Cobalt_SSTuner's Avatar
I was gonna try and help you out but as I was typing, I confused myself and lost my train of thought. Gimme a few minutes to work it out.
Old Sep 3, 2006 | 12:35 PM
Co|3aLt $$'s Avatar
first off.... I'd try this how to, it helped me a lot, and it might do the same for you.
https://www.cobaltss.net/forums/how-guide-43/how-install-leds-cupholders-tons-pics-56k-warning-5639/
Old Sep 3, 2006 | 12:54 PM
wdsoccer's Avatar
where do i get the power from and where do i ground it at?
Old Sep 3, 2006 | 01:53 PM
wdsoccer's Avatar
anyone???
Old Sep 3, 2006 | 02:01 PM
thinking....you can ground it to almost anyplace metal. What we did on my friends car friday night, was run to wires, one on the positive terminal on the battery, and one on the negative. If you run wires from your battery (which is in the trunk). Otherwise you could run a wire from the positive terminal in the engine bay and just find a ground, either on the frame or someplace metal where you can just put a wire on. This is just my guess. It is tough because our battery is in our trunk, and I don't know if you really wanna run wires from your trunk to your dash.
Old Sep 3, 2006 | 02:42 PM
https://www.cobaltss.net/forums/how-guide-43/12-volt-power-tap-grounding-accessories-7241/ < There is the answer to your question.
Solaris99
28
Mar 15, 2017 01:22 PM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
Bohb
Sep 27, 2015 09:11 PM
