LED's?
LED's?
im installing some LED strips under my dash this weekend and i want to know what i would have to do to make them automatically turn on when the headlights come on... splice into the hadlight harness?? which wire?
i wouldn't recommend that if you like to keep your warranty just hook them up to a switch much easier and less messy
i wouldnt hook em up to the hedlights. what i did is i used the center 12v power outlet next to the hand break.. i pulled the wires off the back and used that as a 12v power source then i placed a switched under the HVAC controls .. it's super clean and you can have them on when your in park. and being that they are LED's you can leave them on for days and not drain your battery. i used the micro LED strips and you can cut them to how ever long you need them
and to make your gauges glow like i did mine i cut a strip of micro leds and attached it behind the steeringwheel
and i also have a strip under the arm rest to glow the center along with one under the HVAC controls to glow the switches
the same way as you would the underdash led's, the easiest way is to ground the light in the door and then you only have one wire to run through wiring harness rubber sleeve. and from there its the same. oh and you have to drill a hole in the door panel and use some hot glue to keep it in place.
I have put a shitload of LED's in my car. Trust me, you can splice into a headlight wire if you're running stock bulbs. Two LED strips will draw virtually nothing. If you plan on adding more, just pick up an automotive relay for like $5 at an auto store and run a dedicated 12 guage wire from your battery, problem solved; you could then add as many as you want because the stock wiring would only be controlling your lights, not actually powering them. They'll come on with your headlights... though I'd splice into the running lamp wire so they come on when it gets dark out as opposed to only when the headlights are on. It's up to you.
Suprised none of you gurus thought of a relay.
So for your set up, pin 30 would go directly to the battery, pin 86 would splice into either your left or right low beam headlight wire, and pin 87 would go to your LED's.
I still say use the running lamps and not headlights... cause if you want high beams your LED's will go off. Bosch relays are a godsend... pin 87 in most relays can take 30-40 amps... your LED's will draw less than 1 amp... as long as you stick with LED's you'll never max out this relay.
http://www.oznium.com/forum/ for any further inquiries.
my under dash lights are hooked up to a switch and theyre plugged into fuse slot 21 on the right side of the console using an add-a-fuse....simple easy and NO splicing cutting w/e
my door handle leds are just spliced into the power wires for the door locks and they work perfectly
theyre not in there anymore lol i took em out cuz i almost traded in my car...i just zip tied the on on the pass side to the bottom of the glove box and the one on the pass side i just jammed in and it stayed there
Sure you can use an add-a-fuse and use stock wiring if you want... or you could do it the proper way and run a dedicated line from your battery and not have to worry about how much current your pulling on stock wiring.
LED's barely pull any power...and its direct from an unused fuse slot which works just fine...
Yeah but if he wants to add something that does draw little bit of power, like underglow or a cold cathode kit for example, he won't have to redo his wiring set up. But whatever. I gave my advice.
I only say it because I went the exact same route and used an add-a-fuse, got addicted to interior glow and started piling stuff on that circuit and subsequently fried some wiring. Pays to do it right.
You can buy relays on oznium.com or eBay. I'm not sure where the fuse panel is on Cobalts, and I have reason to believe the battery is in the trunk. Please visit the Oznium forums.. there are many threads with detailed instructions for either the add-a-circuit method or the relay method, pretty much universal to any car.
yea everything is hidden. u have to actually feel for the lights you cant see em at all. every wire is hidden and i tried to make it as professional as possible.
