leds?
leds?
Hey guys. I got these Leds off ebay and I want to know how to wire them.
I saw the how to on wiring leds and neons but all the ways Didn't seem to work.
Here they are
Here they are
from looking at it all u need is a power supply and a ground right? i believe u can tap into ur cig lighter power supply and run a switch for on and off..then ground it to a metal screw
yea what he said hes the led king..i was hoping u would chime in brother..i didnt know which side it went on but that it was that simple
I tried hook the red to the + thing sticking up next to the fuse box under the hood. And the black I put it under a screw and they didn't lite up. I checked the fuse thats on the red wire and it was good.
K Run A Wire From Your Power Source To The Power Post On Your Switch,run Your Positive Wire On Your L.e.d.s. To The Accesory Post On Your Switch , Run A Ground Form The Ground Post On Your Switch To Someplace You Can Drill A Hole In The Metal And Put A Screw In It For A Good Ground ( Or Unbolt Something Metal And Attach Your Wire To That Your Choice )
I Always Run Power Straight To My Switch And It Doesnt Get Hot, I Guess It Depends On The Switch Your Using And The Gauge Of Wire. . . I Always Use 16 Or 18 Gauge For All My Wirning Needs
Good Luck
Good Luck
http://forums.wigm-tuners.org/index.php?showtopic=1354
heres come pics..theres alot to know about led wiring concerning getting proper voltage using resistors and what not..
Good Luck
Good Luck
never had a problem ,knock on wood lol. if you think about it as long as the switch is grounded out by the ground wire you wont have a problem.the switch just make and breaks connection of power,if switch was not grounded . . .it would prob melt lol
