lets try this again lol read:
Old Dec 30, 2005 | 02:46 PM
slvrbalt's Avatar
on the 2.2 l 05 cobalt ls coupe on the headlights there are yellow things for the turn signals is there a way i can remove those to make the whole thing clear?
thnx in advance
Old Dec 30, 2005 | 03:18 PM
celicacobalt's Avatar
well i think you could but we dont know if the yellow reflectors would pop out or not and if so it may leave holes and look bad but if you take the yellow out and tint them and put them back in maybe that would look alright
Old Dec 30, 2005 | 03:21 PM
SilverSS/SC's Avatar
Yep , you need to heat up the outer lens with a heat gun . Pry off the outer lens . Then the chrome bezel inside will come out . The you can just simply take the amber reflector out . It isnt permanently attached , its held in by tabs . To reseal the lens , permatex "Ultra Grey" silicone will match the stock grey silicone used by GM .
Do a search or look in the "How to " section for threads about black headlights for a detailed explaination of removing and resealing the outer lens . Its been discussed many times , so you should find all the info you need .
Old Dec 30, 2005 | 03:23 PM
The 3 tiny slits left when the relector is out are un-noticeable .
Old Dec 30, 2005 | 03:27 PM
ok then so maybe it wouldnt be too bad then, anyone have pics of this done with a chrome housing and no reflectors
Old Dec 30, 2005 | 03:40 PM
hera ya go man
Old Dec 30, 2005 | 04:05 PM
thanks but i still see yellow in the headlight in that pic
Old Dec 30, 2005 | 04:12 PM
Yeah . The circular amber piece is gone , there really isnt anything to replace the curved square amber reflector though . If you take that out too , it just leaves a big black hole as its open to main housing behind the bezel . There isnt a reflector behind it , just a little 194 bulb mounted in the open housing .
Oct 13, 2015 09:32 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
jmelton327
Sep 26, 2015 10:04 PM
