Lowering/Coilovers Thread
hey everyone i have been looking around for quite a while for a good brand of springs or coilvers that are a decent price for the lowering springs im thinking ksports or eibachs and i am not very smart with coilover brands so throw out some brands that you guys have found to be good
How are springs more ghetto than cheap Chinese coilovers? Atleast pedders makes an amazing spring that when coupled with TC shocks/struts anctually has track potential without jaring your teeth loose with shitty spring rates/shock valving.
i wouldnt say stance is necciarily cheap jap coilovers......if they sucked so bad a lot of jdm race cars wouldnt be using them. more then likely they are probablly the best coilovers out for these cars so far. unless you wanna sepdn 4-8k on penske, ohlins and so forth there are no other options for GOOD coilovers.....and even then so good luck getting those companys to talk to you without building a full blown race car. they wont waste their time on a street application
agreed though wrong section. look in the suspension section for different drops and everything else you need to know
Last edited by Boosted_Cobalt09; Jan 23, 2010 at 07:54 PM. Reason: Automerged Doublepost
roflcopter. Stance is in no way shape or form designed or made in China. Designing and production is done in Japan and finally assembly is done here in the States. The only way lowering springs work effectively with the shock/strut, is when there matched or adjustable. So now you have to buy struts/shocks and lowering springs to do it properly. Might as well save up a few hundred more and get real coilovers.
