In The Middle Of Hid Install Please Help
ok so i know this might sound like a noob question but i got my hids from 3bspec today and i am in the middle of my install. idk why i cant figure this out but the answer is probably right in front of my nose. i mounted the ballast and now i have 2 plugs that look like this on each side.
one from the relay, the other from the bulb. one goes to the ballast, where does the other one go? i have gen 1 projectors btw.
bump please i need help i need to get this done
ok seriously i NEED help i still can't figure this out after reading and rereading the how to and the online directions from 3bspec. i know you guys know how to do this. just PLEASE HELP ME!!!
Last edited by the senile J; Jan 6, 2009 at 12:18 AM. Reason: Automerged Doublepost
I'll be doing this later this morning... i think this is where you are stuck..
OK Looking at my kit and the wiring instructions... the kit comes with a relay harness as well, but the plug and play diagram that is shown on the instructions shows the harness to connect the two isnt used at all, so there thus should be no free wires right?
The only thing is that they show a seperate wire going from the stock harness to the ballast... where in the kit the hookup for the stock harness is in the bulb...IDK...i'm lost
here is the diagram i am looking at
http://www.qualityhids.com/
Click on the above link
Scroll down to the bottom of the page
Click on the play button to play the "How to install HID's" video
It should tell you all you need to know
BTW< ur stock wiring is going to put a big strain on ur ballast and eventually blow ur nice new expensive HIDs
i had some crazy problems until i bought the aftermarket harness and did it correctly.
Delta coupe
Sep 30, 2015 08:11 AM
