In The Middle Of Hid Install Please Help
Old Jan 6, 2009 | 12:18 AM
the senile J's Avatar
ok so i know this might sound like a noob question but i got my hids from 3bspec today and i am in the middle of my install. idk why i cant figure this out but the answer is probably right in front of my nose. i mounted the ballast and now i have 2 plugs that look like this on each side.
one from the relay, the other from the bulb. one goes to the ballast, where does the other one go? i have gen 1 projectors btw.
bump please i need help i need to get this done
ok seriously i NEED help i still can't figure this out after reading and rereading the how to and the online directions from 3bspec. i know you guys know how to do this. just PLEASE HELP ME!!!
Last edited by the senile J; Jan 6, 2009 at 12:18 AM. Reason: Automerged Doublepost
Old Jan 6, 2009 | 01:24 AM
CASol's Avatar
one should go from the original harness to the ballest, then the other should go from the ballast the the bulb
Old Jan 6, 2009 | 01:26 AM
nah man there's two plugs like that on each side and only one spot to plug in on the ballast
Old Jan 6, 2009 | 01:30 AM
CASol's Avatar
do you have a pic of the ballast?
Old Jan 6, 2009 | 01:31 AM
calchr2's Avatar
are you trying to use a relay harness or just hook up the ballast to the stock vehicle connectors?
Old Jan 6, 2009 | 03:07 AM
deuce's Avatar
I'll be doing this later this morning... i think this is where you are stuck..
OK Looking at my kit and the wiring instructions... the kit comes with a relay harness as well, but the plug and play diagram that is shown on the instructions shows the harness to connect the two isnt used at all, so there thus should be no free wires right?
The only thing is that they show a seperate wire going from the stock harness to the ballast... where in the kit the hookup for the stock harness is in the bulb...IDK...i'm lost
here is the diagram i am looking at
Old Jan 6, 2009 | 03:12 AM
dragonslayer27's Avatar
it should be either one or the other, if you're using the relay just plug that one in and don't use the one from the bulb.
Old Jan 6, 2009 | 03:27 AM
deuce's Avatar
so i dont need to connect the two together? i can run from my stock harness to ballast to bulb, without the resistor wires going to the battery? This is safe?
Old Jan 6, 2009 | 03:46 AM
Spun's Avatar
http://www.qualityhids.com/
Click on the above link
Scroll down to the bottom of the page
Click on the play button to play the "How to install HID's" video
It should tell you all you need to know
Old Jan 6, 2009 | 08:38 AM
TRANSAM197781's Avatar
i dont know about the kit you got but mine had an adapter plug you had to plug the ballest into then it plugged into the factory plug.
Old Jan 6, 2009 | 08:54 AM
originaladrian's Avatar
BTW< ur stock wiring is going to put a big strain on ur ballast and eventually blow ur nice new expensive HIDs
i had some crazy problems until i bought the aftermarket harness and did it correctly.
Old Jan 6, 2009 | 06:53 PM
do you have a picture of this adapter? because i think this is exactly what i need
RaginChopsuey
Oct 27, 2015 01:27 PM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
Bohb
Sep 27, 2015 09:11 PM
