My HID plan..
Old Oct 16, 2010 | 12:02 AM
WHAT LAG's Avatar
My HID plan..
Alright, i don't know much about HID's so i would love for you all to point out flaws in my logic/plan here. I plan to buy after market 2nd, 3rd, or 4th gen halo headlights (whichever is cheapest). Also buy an HID kit from the supporting vendor here (cant remember name) which basically includes the plug and play bulb and ballast. Planning on 6000k for the bright white look. Then i'd like to take the headlights and take them apart to color match red with my car. I'll also take this time to seal them better because i heard on here that they leak. So basically i'll take those headlights after color matching them, put the bulbs in, find a place to mount the ballasts, and there we go. So go for it.. tell me my flaws because i'm sure i have them
P.S. Before i just buy the gen based on price, what is the best gen headlight? I'm a huge halo light noob So 2nd or 3rd?
Old Oct 16, 2010 | 12:04 AM
TommyP's Avatar
AWD > FWD
Well, the flaw I found is that you're missing a relay harness. Protect your wiring. The quality of all the projectors isn't that good, so basically just pick the one you want based on looks and get those. Also get matching hid fogs while you're at it.
Old Oct 16, 2010 | 12:16 AM
WHAT LAG's Avatar
What exactly does the relay do?
Where can i get HID's for the fogs? Do i just need the bulbs or projectors/ballast too? Sorry.. i fail at headlights.
Old Oct 16, 2010 | 12:20 AM
heathkidder's Avatar
buy hids or ddm tuning
relay just protects your wiring
Last edited by heathkidder; Oct 16, 2010 at 12:20 AM. Reason: Automerged Doublepost
Old Oct 16, 2010 | 12:23 AM
TommyP's Avatar
AWD > FWD
A relay draws power directly from the battery, or the fuse box in the case of our cars, instead of the stock wiring. The stock wiring is too small and will eventually burn out.
The fogs use H11 bulbs. You will need a full hid kit for them too including bulbs, ballasts, and another relay harness. Remember this, every HID bulb needs it's own ballast. Our fogs are already projectors so you're good there.
Buyhids.com and 3bspec.com are both supporting hid vendors on this site and are both excellent places to buy from.
Old Oct 16, 2010 | 12:33 AM
WHAT LAG's Avatar
Ok thanks. Relays seem like a good idea. HID fogs will be later. Answer me this though.. on the halo headlights.. are the lows the only projectors? SO the HID's would go in the lows and i would only use the lows.. right?
Old Oct 16, 2010 | 12:36 AM
kidcrash603's Avatar
We at buyhids can also complete your entire order from start to finish, including providing the lights, painting, sealing, and pre-installing your hid kits in them.
We are on vacation until the 21st, but if you go to BUYHIDS.COM HID Lights HID Kits Xenon Headlights Kit HID Headlight Kits HID Conversion Light and place you order, and use the code 10OFF at checkout, you can save 10% on your order.
Old Oct 16, 2010 | 12:37 AM
BumbleBee's Avatar
I'll sell you my green fogs...
Old Oct 16, 2010 | 12:51 AM
WHAT LAG's Avatar
I think i can handle painting them and installing them with a little bit of guidance, maingly because i want to save money
Old Oct 16, 2010 | 01:03 AM
i dont even have a relay well i do but i never used it lol mainly cause i was in a hurry and never got around to it.
Old Oct 16, 2010 | 01:11 AM
Ddm tuning ftw!
Old Oct 16, 2010 | 02:53 PM
WHAT LAG's Avatar
So you ditch the regular wiring and run it all the way to the battery or fuse box? Besides running it, is it still plug and play and where does it plug in?
Old Oct 16, 2010 | 02:57 PM
TommyP's Avatar
AWD > FWD
Sort of. The hids go in the lows, and so you have a projector hid for lows. You will still have highs, they're just halogen reflector high beams. The high and low beam on the projectors is split between two separate bulb housings.
The relay kits are plug and play, and you still use all of the wiring, they basically just "add on" to the existing wiring.
SSnRXP
Dec 4, 2015 11:02 PM
chefhhr
Oct 26, 2015 10:36 PM
allpro666
Oct 6, 2015 08:11 PM
dieGone
Sep 23, 2015 10:20 AM
Brian MP5T
Jun 9, 2007 08:25 PM
