need help with led tailights
Old Apr 28, 2009 | 09:46 AM
chrism0589's Avatar
i bought the led tail lights from modern proformance and over the weekend i was trying to put them on but the connector on outer lights (the ones with the leds) is defferent then the connector on the stock lights. is there an adpator or soemthing i need??
can someone please tell me what i have to do?? i thought these were jus to plug in but i guess not....
Old Apr 28, 2009 | 09:58 AM
proZak's Avatar
all you have to do is remove your bulb and plug the led harness right were you pulled the bulb out
Old Apr 28, 2009 | 02:18 PM
chrism0589's Avatar
its a different conector though????
Old Apr 28, 2009 | 02:31 PM
proZak's Avatar
the connector on the back of the led taillights plugs in the socket that your stock bulbs were in.... if this doesn't help take a pic of the connector
warrenb213's Avatar
...the led lights should have like a card u'd stick in a slot. u stick that card into the slot that would normally stick the stock bulb(which, if u look on the end, has a "card" as well).
Old Apr 30, 2009 | 09:15 AM
ExCaLdA's Avatar
i had the same problems when i tried indtalling mine. you need to take the legit light bulb out and match up the red with red. black with black and than plug it .. thats all.
Old May 3, 2009 | 04:09 PM
chilllaxeng's Avatar
yeah i bought once too any they did not fit right either i had to cut the ballest all up to make them fit well worth it
chefhhr
Oct 26, 2015 10:36 PM
How to Guide
57
Oct 15, 2015 11:56 AM
dieGone
Sep 23, 2015 10:20 AM
jonnycat
Sep 19, 2015 12:58 PM
ATOMbomb
Sep 11, 2015 10:48 AM
