New Projectors arrived! Pics! Need help with the HID setup though..
Old Feb 4, 2008 | 07:01 PM
Silv3r's Avatar
So they arrived today!
So there's a bit of wiring for the halos/leds. Nothing to worry about, but what should I tie them into though? I want them on all the time when the headlights are both on or off. I have an 07 keep in mind.
And here's the HID kit, mobilehid.com 6000k H1's:
Now, I Know exactly how to wire em in, cept for the plug in the middle. Think I can cut the 2 wires that run from the lowbeam on the projector and use them to power this? Its labelled as the remote turn-on from the headlight, and you're supposed to just unplug it from the stock headlight and plug it into the hid kit.. cept that doesnt work here as im using the stock plug to adapt for 2 headlights.
Here's pics of the lowbeam projector (gonna be useless as the hid kit draws its own power from the batter), and under that a close up of the remote turnon plug.
So what do you think? Chop off the connections on the lowbeam projector that will be replaced with the hid kit, and use that to splice into the remote turnon? It makes sense in my mind but I want to double check with you guys first. Thanks for any info!
I guess I should have resized the pics a bit smaller too >.>
Old Feb 4, 2008 | 07:06 PM
Dayta's Avatar
how much did they cost?
Old Feb 4, 2008 | 07:08 PM
BlackLsCoupe's Avatar
those conectors look like 9007's
Old Feb 4, 2008 | 07:13 PM
Silv3r's Avatar
The blue connector's are indeed female 9007s, to adapt the old headlights to the new without splicing or ripping apart your stock harness.
$250 for the HIDs (got em in a GB for $120, then they took forever to ship so they actually discounted the kit in full except for shipping costs).
about $150 + shipping for the projectors.
Old Feb 4, 2008 | 07:20 PM
an0malous's Avatar
do NOT chop your stock wiring and power it with them.
that piece your talking about is a relay, so that you draw power directly from battery during the ignition phase.
there is a MASSIVE draw of power to ignite HID bulbs (up to 25,000 volts)
drawing that much power through stock wiring is not a very good idea, for obvious reasons.
Old Feb 4, 2008 | 07:26 PM
Silv3r's Avatar
This is the diagram for the HID kit:
See the plug I'm talking about isn't the relay, the relay is completely seperate. I think all this plug does is tells the relay when to power on. So seeing as I would only want it to call for power when I want the lowbeams on, wouldnt I just splice these 2 together..
I was hoping you'd answer me Anomalous, I see you posting about this **** all the time.
Old Feb 5, 2008 | 06:20 AM
Silv3r's Avatar
I've figured out how to wire them up, but can anyone help me with the remote turn-on plug?
Old Feb 5, 2008 | 06:32 AM
Dayta's Avatar
nicenice
Old Feb 5, 2008 | 06:37 AM
Jackalope's Avatar
The remote turn on is what the factory harness connects to.
Old Feb 5, 2008 | 09:11 AM
Rangerondubz's Avatar
Pics of them on your car?
Old Feb 5, 2008 | 09:17 AM
JimHarr18's Avatar
i bought those a few days ago, hopefully i'll get them in soon. look pretty nice. but they require wiring? was really hoping for plug and play cause i'm not gonna mess with wiring.
edit: okay, i just realized that the lights are plug and play, but halos/leds need wiring... der, helps to read! how hard/easy is wire splicing, and i'm guessing the wiring is done right on the headlight itself going into the plug, correct?
Old Feb 5, 2008 | 09:21 AM
iLLmaTic3s's Avatar
pics ASAP!!! haha im thinkin bout these..and im curious to see wut they look like on a silver cobalt
Old Feb 5, 2008 | 06:46 PM
Silv3r's Avatar
Alright but even so that factory harness is going to be used on the plug and play for the headlight, which is actually just going to be highs seeing as the lowbeam is going to be replaced with the hid kit and wirirng harness.
So what I need to know is if instead of taking the factory headlight turn-on plug and using that, can i just splice lower down the line at the lowbeam so my highs are still using the factory plug, catch my drift?
I'm going from one headlight to two.. but the hid kit requires the factory harness.. but I cant use it because the highs are going to be using it. So I want to splice into the unused lowbeam harness and use that for the remote turn-on for my hid kit. NOTE again this is not the relay, just a switch really.
I can't make it any clearer, can anyone see what I mean?
Old Feb 5, 2008 | 06:49 PM
Dead Zen's Avatar
i wanted to see these new (3rd style) projectors on a car.
Old Feb 5, 2008 | 08:30 PM
Silv3r's Avatar
As soon as someone can help me I'll get em in, if not by the weekend I'm gonna take a chance and try it.
Old Feb 10, 2008 | 12:04 PM
06blackSC's Avatar
Ok. The best way i can think of (and not much thought going into this) Is to take the wiring from the low beam portion of the aftermarket headlight harness, cut the connectors off and cut the connector off the remote turn on for the HID kit. Solder the two lines together and heatshrink wrap the connectors. this way you can use the HID kit wiring and keep your factory harness intact incase you need to swap back to stock.
for the other headlight, you will not need to make the same connection because you only have the one remote turn on source. For the other light, just disconnect the connectors from the low beam wires to the bulb and either tape them up, or, cut the connectors off and wrap the end of the wires/heat shrink them to keep them water tight. this way you can just run the low beam directly from the ballast for the other headlight without having to worry about the remote source like you did the first headlight.
I'll be curious to see how you make out with this. I'm looking to do the same thing you are.
RaginChopsuey
Oct 27, 2015 01:27 PM
dennis69
Oct 20, 2015 04:49 PM
Oct 13, 2015 09:32 PM
SSLOW06
Oct 1, 2015 07:21 PM
footballplaya3k
Sep 30, 2015 09:39 PM
