New Spoiler Install: Bolts, glue, both?
Old Jul 12, 2008 | 10:22 AM
LucyBelle's Avatar
Hi.
After doing a search in this forum and reading some posts, it sounds like the factory GM spoilers are installed with both bolts and some kind of adhesive? Does anyone know if it's 3M tape or some type of construction adhesive?
I just got a new ABS low-rise for my LT and haven't put it on yet. I'm wondering how other guys have done it, with supplied hardware, glue, or both. Does it need glue and hardware to get a good installation?
The spoiler I have has threaded holes in the base, into which supplied bolts will go. I kind of expected studs to be mounted in the spoiler and nuts for the other side. Is this how all spoilers work?
Thanks for your help!
Old Jul 12, 2008 | 05:36 PM
BitchyTheDwarf's Avatar
Is this a OEM spoiler or aftermarket? My aftermarket spoiler came with some little tab things that stuck in the little holes to show you where to drill the holes in your trunk. After the trunk holes were drilled, then you thread the studs into the spoiler, through the trunk, and attach it with the nuts. I ended up needing longer bolts because they did not line up with the spaces underneath where the stock spoiler would have gone.
Old Jul 12, 2008 | 08:26 PM
LucyBelle's Avatar
This is an aftermarket spoiler. It has threaded holes tapped in the spoiler mounting points and comes with four bolts- no studs.
Just wondering if I should use some sort of glue too, since that seems to be what GM does with factory spoilers.
Old Jul 12, 2008 | 08:29 PM
Cirrus's Avatar
Elmers and some elbow grease (pick it up at your local Autozone or Advanced AP) will do the trick.
Old Jul 12, 2008 | 08:32 PM
EXsoccer1921's Avatar
"where do i find elbow greese? i see everyone saying you need it for pretty much every install, but i can't find it anywhere"
anyone remember that?
Old Jul 12, 2008 | 08:59 PM
Cirrus's Avatar
it made my night.
Old Jul 13, 2008 | 10:36 AM
GM glues theirs down to make it harder to swap out
Hmmm perhaps some LocTite on the bolts will work. Just check the bolts from time to time. I haven't had any problems with my spoiler coming loose.
Old Jul 13, 2008 | 01:51 PM
LucyBelle's Avatar
Thanks for the advice.
And the deck stripes look sweet!
DarrenGC
Dec 24, 2021 01:55 PM
SSLOW06
Oct 1, 2015 07:21 PM
footballplaya3k
Sep 30, 2015 09:39 PM
Tupp
Sep 30, 2015 08:18 PM
Slick_Nick
Sep 28, 2015 09:15 PM
