Official Retrofit Thread
#778
my best friends cat used to hide under whoever's exhaust was the warmest, only problem was you had to make sure he wasn't under there if you went to leave
#780
wich wire do the resistors go on? also figured out my halo wiring.. the one i got donw its like the lenz arent on all the way and stick out some. what yoou guys seal with?
#781
i got resealing glue with my kit. i laid the sealant in the channel and heated it up with a hair dryer and then just pushed the lens on the best i could, all my clips are broke too. so far no moisture or anything
#791
^same here..
if these were mine I'd be doing alot of things to them.. I know I could get to liking the design but it would take a lot of work by me shaving and filling parts of them in (namely the LEDs for one)
#792
Yea the LED's it what turns me off. I just got my hands on a set of stock headlights. Gonna build a mold and shave some **** to try and fit dual projectors in them. It's gonna be a process but I'm determined to make it work! lol
#793
i did some fitment testing on the car last night testing out both projectors
just a smidge low, but Ill get her all dialed in here shortly
#795
lots of cosmetic stuff..
-getting the grilles custom painted
-working on a few retros
so i took the bumper off as it makes both the above processes easier
then
-removing intake
-removing hotside pipe
-removing intake manifold
-removing valve cover
-removing ECU
^removing some of that for ease of removal of other parts. plan on painting the intake manifold and valve cover and possibly re-routing a few vac lines to clean up the engine bay a little bit
after that.. car will go up on jack stands and I'll be recoating much of the car underneath with a rust converter then underbody coating.. seeing as now its not driven in winter I might as well stop whatever oxidation is occuring and clean her up nice under there as well. I'm waiting for the cold weather to stop for a majority of this work.. that and I'm busy with retros anyways
then
-removing intake
-removing ECU
