Official Retrofit Thread
#806
wait wait wait, am i seeing that correctly? the hids connected in series i belive, or that parallel? i cant remember which its called, but i know what it looks like. clean wiring as well. plannin on redoing my retros after tax return, the halos are going to **** and plan on making some additions.
#807
i just have the bulbs connected to one another to protect the connections. i still have to run two ballasts and all that fun stuff like any other HID kit.. nothing special going on here (unless you want to talk relay harnesses)
#809
2 relay power connections
2 switched relay connections
4 grounds
4 relay to ballast connections
2 High Beam Solonoid Connections
8 Ballast to Bulb connections
4 CCFL to power inverter connections
4 LED/power inverter to OEM harness connections
so what is that 30 connections? simple!
#811
let me think out loud here..
4 grounds
4 grounds
#817
right now these will be running lows/highs in the outers, then the inners will be highs only. so two projectors running on lows, then all four on highs. I could've removed the cutoff shields on the inner ones, but i chose to keep them for appearance reasons with my pink demon eye I painted in. all I did was tie the solonoid wires together between the projectors so their cutoff shields act in unison.
#820
here is a couple of pics from my quad projector retrofit. got the idea from Padlock. was just gonna put in a set of FXrs at first but after seeing what he did i figured i could experiment a bit with my Gen 1 headlights. the plan is that the FXr will be my low beam and highbeam. The original projector has essentialy had the shroud trimmed back pretty radically it will be for highbeams only.
anyways PIC's
Lens off
Front Facia out and the bits removed. housing dremmeled out behind where the Gen 1 projector will go. The Fxr is going where the original projector went.
picture of inside the projector with the shroud trimmed back.
Teaser Pic of Gen 1 with the projector in the wrrong place.
i dont have the projector actually mounted yet. thats what its gonna look like though. just with a projector in the other spot as well.
anyways PIC's
Lens off
#822
a few more pics from todays progress. gonna be a couple days b4 i get any more done while i wait for the projectors to get here
setup for hardmounting the highbeam only projectors. and the pc power supply i used.
i LOVE JB Stick
Did i mention i love JB stick
i LOVE JB Stick
