ok.....more bowtie questions...SORRY
Old Feb 28, 2007 | 03:31 PM
SC07's Avatar
ok guys, so ive been searching for about an hour plus on how to paint bowties and im still confused.
im really good with paint so thats not the problem, but i cannot seem to figure out from text how to remove the rear one...it seems like a hit or miss/break/scratch your car thing
anyone have a good way???
and for the front one, i guess it pops or screws out???
can you seperate the gold from the chrome???
thanks a ton
kev
Old Feb 28, 2007 | 03:41 PM
flyhhr's Avatar
strong fishing wires or strong wire it's held on with double sided tape.
Old Feb 28, 2007 | 03:47 PM
RaineMan's Avatar
use some strong fishing line... or get a hairdryer and heat up the rear bowtie a little (not too hot) then get it off with some dental floss. It's stuck on with double sided tape.
The front bowtie has plastic posts sticking out of the back of it and it is held on with two threading nuts. Be really careful getting it off or the posts may break.
As far as I know you can't seperate the gold from the chrome... so just use some painters tape along the seam between the gold and chrome and you should be just fine.
Old Feb 28, 2007 | 03:50 PM
SC07's Avatar
ok thanks guys
Old Feb 28, 2007 | 05:35 PM
SS_Ry's Avatar
it can be done if your careful
Old Feb 28, 2007 | 06:17 PM
flyhhr's Avatar
I don't think the cobalt bowtie is the same size but I changed mine with a billet one
Old Feb 28, 2007 | 07:32 PM
SC07's Avatar
hmm u guys used fishing line???
the back bowtie doesnt want to ude and i cant get a socket to fit the front
how did u guys ratchet the front hex's out???
and how hard was it to get the back off???
i dont want to break anything
Old Feb 28, 2007 | 07:47 PM
spaz's Avatar
Take the rear one off and throw it in the garbage.Then unbolt the front one scuff it, clean it mask it, spray it with some adhesion promotor get some color matched spray paint from your dealer paint it and put it back on the car.
Old Feb 28, 2007 | 07:49 PM
StevesBlack06's Avatar
make sure that glue that holds the rear emblem on is nice and hot before you try to it off. i wish i would have thought of the fishing line thing when i did mine. the front one is like a 10mm i think correct me if im wrong. u gotta weasel your hands down in there or take out yur grill... its not hard to take it out, just some clips and plastic push tabs... just be careful and take your time and you wont have any problems
Old Mar 1, 2007 | 10:23 AM
Red07SSNA's Avatar
You want the rear emblem uncomfortably hot-to-the-touch before beginning to pull on it so the glue is soft and pliable.
The front emblem is held on by 2 10MM nuts -- use a nut driver or 1/4" ratchet. You do not have to take off the grille to get to it.
Old Mar 1, 2007 | 11:53 AM
Swan SS's Avatar
the front bowtie isn't too hard to get off, just takes patience.... i popped off the push clips in the top of the grill to make it easier to get at... as for the back bowtie i plan on doing mine tomorrow, but i am just going to pain it on the car... just mask it off and cover the back with an old bed sheet or something.
Old Mar 1, 2007 | 11:57 AM
plyboy-illest's Avatar
yup and don't forget the rubbing compound to get rid of the rest of the tape...
Old Mar 1, 2007 | 12:29 PM
SC07's Avatar
so something like goo gone?
Old Mar 1, 2007 | 12:42 PM
Red07SSNA's Avatar
Once I take off emblems/decals I soften the glue with Prep-All (degreaser and wax remover available at Autozone) then I use regular wax to finish removing the glue. Takes a couple of applications but all the glue comes off and the paint is glossy afterwards.
Old Mar 1, 2007 | 12:50 PM
RuSSo-29's Avatar
I took mine off in the summer..... I used soap and water and just kept pulling! lol, tok about 2hrs.... and my fingers were in horrid pain.... but not a single scratch.
Old Mar 1, 2007 | 01:08 PM
Halfcent's Avatar
I'm old school
I was lucky. I debadged the day I got my car, and was only manufacturered the week before, so the tape hadn't really set up yet. I hit it with the hair dryer and it fell off clean. I didn't have to scrape anything.
The front really is quite easy. Use a deep well socket if you have them, your standards may be bottoming out on the posts. I was able to reach from the top.
Old Mar 1, 2007 | 02:10 PM
SC07's Avatar
eah i got them both off and the glue is almost all off the back
but around where i was prying at the emblem i managed to put a number of little finger nail scratches in the clearcoat, they are like all around where the emblem was
kind of annoying
what can i do about those?
Old Mar 1, 2007 | 02:18 PM
XM15's Avatar
kind of annoying
I've got some annoying scratches on mine too; they are right where the corners of where the symbol was, so you can tell the bowtie had been there. Can anyone recommend a product to get rid of the clearcoat scratches? SC07 and I would appreciate it.
Old Mar 1, 2007 | 02:35 PM
Ric's Avatar
Ric
I just removed rear and gm on sides last Monday. Took 5 minutes. Heat gun on it for a couple of minutes. Fishing line at one end and pull and wiggle. Goo-be-gone of glue and heat gun. Very easy.
Old Mar 1, 2007 | 05:50 PM
SC07's Avatar
yeah so i just checked on the scratches again, so
i assume they will just buff/ polish out when i do my whole car spring time???
or should i buy some swirl remover
Old Mar 1, 2007 | 06:21 PM
Swan SS's Avatar
you can probably use the swirl remover but unless they are real deep, the buffing should clean that up nicely
Joe09
Sep 18, 2015 09:22 AM
vred05
How to Guide
28
Mar 5, 2011 12:27 PM
SilverSS/SC
Jul 2, 2007 11:32 PM
watersedge1234
Aug 24, 2006 05:32 PM
CTCOBALTSSS
Jun 14, 2006 12:03 PM
