plasti dip
it makes it look flat black!!! same as you got now...only diff you can peel it off if no likey anymore..but you can buy glossifier they sell it online i never seen the glossifiers in stores and it makes it shiney
i just sanded with like 500 then 800 then 1000, i really only sanded enough to scuff it up. then primed them with 2 coats paint then cleared.
and dont forget to clean after sanding obviously haha
https://www.cobaltss.net/forums/appe...wheels-269237/
Check that post out. it should answer some questions you may have.
well mine has actual rim paint from adv auto. would sanding take that off and not scratch my rims, so when i re paint you wont see the scratch marks? honestly i want tc tims... BAD
well if you have ss/sc rims or ss/na rims when you sand it your never probly get that center polish back if your not worried about it go for it...but if you want them black for ever!! powder coat them...
painting wheels doesnt not work with winter snow/ice. I put at least 8+ hours into my wheels, prepping and painting, etched primer, 3-4 coats of paint 3 coats of clear. Chipped first snow storm.
Plastidip does not chip or peel unless you do it incorrect.
