Previous Owner Problems - HIDs in Stock Housings
All-
Bought my 2008 ss/tc about 6 months ago. PO told me it has HIDs and HID foglights. Balasts/harness are there and visible (best I can tell they're 55w) - in the stock housings, not projectors. Realizing this is not the best and I am parking the car for the winter I want to build a set of retros. I've been reading up on it and it does not seem hard but the only thing holding me back is dealing with how everything is wired. Highs/low work, odd thing is they are "switched" so low is high and viceversa. Is there anything possibly salvageable from what I have or should I just start over with a whole new setup since we don't know the quality of everything. Any advice?
when u retrofit. its common to go to a H1 bulb or D2S. A new harness is used (Bi Xenon) which has a extra connector that goes to the projector you retrofitted in. That connector is what controls the solenoid inside the projector and that makes your high beams when there is current running thru it. The flap drops down and high beam is made.
camaromanss1992
Oct 1, 2015 10:51 PM
Cptnslo
Sep 24, 2015 09:32 AM
XStylus
Redline Goods
17
Sep 3, 2015 10:30 AM
