Problem caused by HID maybe?
Old Jun 28, 2010 | 02:05 PM
beefbusta's Avatar
Hey all, I bought some HID's off this site used, that worked great when they were in. Well while they were in I started to notice that my battery was draining all the time with the car off (yes everything was turned off lights, interior stuff, etc) . I figured eh maybe it's a bad battery, so I replaced the battery. Still the same problem. So I took the HID's out. The problem still occurred. I used a test light and discovered regardless of the headlights it was still draining a ridiculous amount of power, enough to kill my battery with the car off and a full charge in about 6-8 hours (new battery too btw).
It turns out the BCM was bad. But all was functioning properly prior to my installation of the HID's. I have my new BCM in and the car works great but i want to put the HID's back in. I'm unsure if the HID's could cause a BCM to go out and I can't find any topics on this. If they can cause a BCM to die then I will just stay with the stock look. Any help is appreciated.
Old Jun 28, 2010 | 11:02 PM
operatic's Avatar
Safest thing to do is get a new relay harness and run the HIDs off that. If it fries anything, it'll fry the HID harness.
Can't say 100% that frying the BCM was caused by the HID; there's too many possible variables. The HIDs probably just made it more apparent.
Old Jun 28, 2010 | 11:28 PM
Gestapo007's Avatar
^listen to this guy
Old Jun 29, 2010 | 11:14 AM
beefbusta's Avatar
Cool thanks for the reply. I reinstalled the HID's last night and damn they look too good to not have in there. Everything seems to check out okay, Im just about to use a test light to see if my battery is still being drained. Hopefully it works out okay. Thanks for the help.
Solaris99
28
Mar 15, 2017 01:22 PM
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
ernnyyes
Oct 2, 2015 05:16 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
