Problem with my HIDs
Old Aug 19, 2010 | 07:05 PM
09turbo's Avatar
Well I have had some cheap eBay HID kit in my fog lights for over a year now. On my way home from work i saw that only the drivers side was lit in the reflection from the car in front of me.
When I try to turn it on, the passenger side flickers a bit and just does not light up.
My guess is the balast, or a connection.
Anyone want to reasure me? Thanks.
Old Aug 19, 2010 | 07:07 PM
heathkidder's Avatar
hmm maybe cause there from ebay lol ddmtuning makes them for just as cheap and prolly with a warranty. atleast i think thats the site? if sum other reason it could be the ballasts knockin around or loose wire
Old Aug 19, 2010 | 07:09 PM
09turbo's Avatar
Lol, yeah I went with eBay cuz everyone I know that bought an expensive kit had trouble like 3 months after they got it. This is litterally my first problem with mine. I can check ddmtuning out. All I need is the balast's, if need be.
Old Aug 19, 2010 | 07:11 PM
yeah i have there slim kit and it fits perfect underneath the headlight assembly piece i didnt even have to bolt mine down
Old Aug 19, 2010 | 07:19 PM
09turbo's Avatar
I have mine double-side-taped to my inner fenderwell haha. I will check out the slim kit. Thanks man.
G5 looks good btw. I want a black G5 trunk, maybe sell my shaved cf balt trunk.
CordiaDOHC's Avatar
my ddms are still running strong
Old Aug 19, 2010 | 07:23 PM
09turbo's Avatar
Good to know. Im waiting for the site to load. Guess everyone wants their HID's.
Old Aug 19, 2010 | 07:25 PM
lol i got mine real cheap and thanks the trunk would look sweet wingless but i remind u that the g5s only come with a wing so if you wanted wingless ud have to fill the holes
Old Aug 19, 2010 | 07:29 PM
09turbo's Avatar
Yeah they're listed for real cheap. I just might do that. Wish I didnt have to buy the bulbs but oh well. And yeah I realized that. I can get a black one and either put my low rise back on or be cheap and cover the holes with some black vinyl
Old Aug 19, 2010 | 07:31 PM
im tryin to get the high rise i think ill like it better than the low but id go wingless if nething but owell lol goodluck with the hids all i have in my fogs right now are sum aftermarket bulbs that are blue and then i have the 6000k hids low beams from ddm
Old Aug 20, 2010 | 11:12 AM
09turbo's Avatar
Thanks good luck to you too. And how do you like the HIDs as headlights? everyone I see with HID's in a reflector housing it just blinds the **** out of me, and I dont want to do that to other people. Much less mess up my housing.
Old Aug 20, 2010 | 11:45 AM
TommyP's Avatar
AWD > FWD
I would try swapping the ballast between the left and right side to see if the issue follows the ballast
Old Aug 20, 2010 | 11:52 AM
kidcrash603's Avatar
If HIDs are used in stock housings some painting and adjusting has to be done to avoid the blinding issue.
Whoevers HIDs you go with, Slim Ballasts are a total waste for a cobalt owner. The regular ballast fits under the headlight bracket with plenty of room. No need to spend the extra on a slim unless you just want one.
Old Aug 20, 2010 | 11:53 AM
aweSOMeBalt's Avatar
+1!
I'm going to try that with mine. Ever since I installed mine only my drivers side comes on.
Old Aug 20, 2010 | 11:56 AM
09turbo's Avatar
that would be a good idea. you a smart man.
Old Aug 20, 2010 | 01:05 PM
TommyP's Avatar
AWD > FWD
Also make sure your drl fuse is removed. R u running a relay harness? That can cause problems. If the problem does not follow the ballast, switch the bulbs. If the problem does not follow either, it may be your wiring.
Old Aug 20, 2010 | 03:07 PM
im a base so i wired mine into the parkin lights
Old Aug 21, 2010 | 07:54 PM
09turbo's Avatar
Thanks man I will check it out.
Old Aug 21, 2010 | 07:56 PM
TommyP's Avatar
AWD > FWD
Don't they make special hid bulbs for reflector housings? Called like a 9007R bulb or something?
Old Oct 3, 2010 | 01:26 AM
09turbo's Avatar
hmm never heard of that... PM a link?
Old Oct 3, 2010 | 01:42 AM
BlackARCA06's Avatar
Just aim them low ive never been flashed or complained to.
Old Oct 3, 2010 | 01:47 AM
09turbo's Avatar
what k you got?
Old Oct 3, 2010 | 01:51 AM
what k you got?
8000.
Old Oct 7, 2010 | 11:23 PM
09turbo's Avatar
How low are you talking? i want to be able to see still :p
anyone got any info on the special hids for reflector housings?
Old Oct 7, 2010 | 11:30 PM
ecot3c inside's Avatar
check your connections, It might just be the bulb too try swapping bulbs and ballasts, and don't stick it to the inside of the fender mine fell off just tuck it behind your lights they will not go anywhere.
