Problem with my HIDs
Old Oct 7, 2010 | 11:31 PM
TommyP's Avatar
AWD > FWD
Originally Posted by 09turbo
How low are you talking? i want to be able to see still :p
anyone got any info on the special hids for reflector housings?
I still can't remember where I heard that from. Should look like this though
This is a d2r bulb, see how it's painted? it blocks some of the light to prevent glare, like a cut off line does, only this is directly on the bulb. I think this is something like what they use in the Prius.
Old Oct 7, 2010 | 11:49 PM
09turbo's Avatar
Originally Posted by moranjames89
check your connections, It might just be the bulb too try swapping bulbs and ballasts, and don't stick it to the inside of the fender mine fell off just tuck it behind your lights they will not go anywhere.
People tell me this, but where exactly behind the headlight? I need to get back under there and see if I can see what you are talking about.
And no I have not fixed it, I have been so busy. I am dissapointed in myself
Old Oct 7, 2010 | 11:50 PM
09turbo's Avatar
And thanks Tommy, I have seen that bulb type before but I didnt realize what it was. Wonder the cost difference...
Old Oct 7, 2010 | 11:53 PM
TommyP's Avatar
AWD > FWD
I put my ballasts on the metal "shelf" under the headlight bracket.
Old Oct 7, 2010 | 11:54 PM
09turbo's Avatar
So if I'm looking at the front of the car, I would slide them twards me, in that black piece the headlight bolts to? I confoosed
Old Oct 7, 2010 | 11:58 PM
TommyP's Avatar
AWD > FWD
You could screw them to the underside of the headlight bracket. But if you take that bracket out, you will see a small piece of metal that the front of the bracket bolts too. It's just wide enough to fit two ballasts on side by side, perfect for your low beam and fog light ballasts.
Old Oct 8, 2010 | 12:01 AM
09turbo's Avatar
So I can still get to it without taking that bracket off?
Old Oct 8, 2010 | 12:02 AM
TommyP's Avatar
AWD > FWD
no you would still have to take the bracket off. There really isn't a good place to get to the ballasts without taking the brackets off.
Old Oct 8, 2010 | 12:06 AM
09turbo's Avatar
Mine came with a mounting braket that the ballasts slide into, so i double side-taped them to the inner finders haha, and it has held up well, But thanks I will look for that slot.
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
