projector help.. again
Old Apr 14, 2007 | 03:24 AM
VeNoM0713's Avatar
i finally got around to taking pics of my headlights. basically my problem's are.. when my lows are on, my highs come on a little bit, when my highs are on, my lows come on a little bit also, and now my gf brought to my attention that my driver's side headlight is dimmer than the passenger side. do you think it's the bulb? i took a pic of them on a wall also to get some advice on how i can aim them better.. heres some pics.. and btw, the 3 prongs arent bent lol.
heres a pic showing how the passenger side low is brighter then the drivers side..
you can see the light output differance between the left and right..
pic with the highs on
pic with the lows on
i'm guessing it's faulty wiring and i cant fix the problems.. but if any of you have suggestions, im open for them. thanks
Old Apr 14, 2007 | 07:52 AM
Jackalope's Avatar
Why the problems? Those things are plug and play this doesn't make sence. Did yo lose the wiring harness they come with?
Ok anyway it looks like first off you have a bad ground on the 1 low beam thats dim, secondly you have a wire crossed thats why the hi's are dim when the lows are on. In fact it may just be that crossed wire is messing it all up! What happened to the harnesses that came with them?
Old Apr 14, 2007 | 07:56 AM
VeNoM0713's Avatar
well it doesnt make sense because it's like that on both sides.. i dont know whats going on with them. and no, i still have the wiring harnesses
Old Apr 14, 2007 | 08:00 AM
Jackalope's Avatar
And all you did was plug them in and this is the result?
Old Apr 14, 2007 | 08:05 AM
VeNoM0713's Avatar
yes sir.. i mean i switched out the white leds in the angel eyes to blue but i mean i didnt mess with the wiring harness or anything.. i mean it couldnt be the white and black wires that power the halos/3 top leds so its gotta be something in those wiring harnesses..
Old Apr 14, 2007 | 08:14 AM
Jackalope's Avatar
Disconect the halos and the LED,s and see what happens. I'd be willing to bet you put 1 of them in backwards and thats why your having the problems. Remember LED's only work 1 way. The longer lead is the + and the shorter lead is the -.
Go disconect everything but the regular lights and see if that doesn't get them working correctly. Then you just need to see where you crossed one of the LED's
Old Apr 14, 2007 | 08:19 AM
VeNoM0713's Avatar
well all of the angel eye leds are working.. lol i made sure of it.. but even so, why would the leds mess up my regular lows and highs? they arent even connected to them. but when it gets nicer out, ill try what you suggested.
Old Apr 14, 2007 | 08:26 AM
Jackalope's Avatar
Because the LED's if installed backward will allow currect to leak from + to - and act like a bad ground. Installing the incorrect light bulb for example will have almost the same effect. Say you plg in a 3156 where a 3157 belongs, well your turn signals won't work right front or rear, your headlights will be all screwy, and your 4 ways will look like a railroad crossing when you hit them! That and since the only thing you did was mess with the LED's and its easy to mix up the anode and cathode on an LED then thats why I say its got to be the problem.
Let me know if this helps and good luck.
Old Apr 14, 2007 | 09:08 AM
CCBalla10's Avatar
How in the world did you change the halo leds'? where did you get them and how did you do it?
Old Apr 14, 2007 | 09:31 AM
mkulrey13's Avatar
err. ok look at the the gray connect you used to plug into the harness. those pins inside bend. esp the middle one. rebend them foward and keep doing it till the lights dont come on with the lows. mine did the same thing and theres about 47348239 threads.
Old Apr 14, 2007 | 09:57 AM
CCBalla10's Avatar
Mkurlrey13....since you are the LED specialist how can i change the LEDs in my halos? mine aren't that bright
***** Also is that what the beam pattern is possed to look like when they are aimed?*****
Old Apr 14, 2007 | 06:08 PM
VeNoM0713's Avatar
LOL i knew you were gonna come on here. im the one thats always having problems with these and i made sure i wrote " 3 three prongs arent bent" lol its just not workin for me man.. i made sure those prongs werent bent.
ok.. say i installed one backwards. it wont light up correct? even so.. i made sure the longer wire was soldered to the + and the shorter one to the - and i know they all light up because i made sure. but ill still disconnect them and see what happens. thanks for working with me on this though
Old Apr 14, 2007 | 07:20 PM
Jackalope's Avatar
It all depends how you wired them up. If for example you took all the + and soldered them together and all the - you did the same thing BUT you crossed one set they'll bleed current back thru and cause a short.
If this isn't the problem then I have to ask if you swaped out ANY other bulbs when you put these in.
Old Apr 14, 2007 | 07:25 PM
mkulrey13's Avatar
the problem is IN the connecter... the PINs arnt making connection. time to take it apart and fix it.
Old Apr 14, 2007 | 07:27 PM
Jackalope's Avatar
MK seems pretty certain dude! Check them connectors before you cut anything.
Old Apr 14, 2007 | 07:32 PM
VeNoM0713's Avatar
what do you mean in the connector? and how could i take it apart and fix it lol.. i would like to get these fixed though
and like i said, im gonna disconnect the wires and see what happens.. and i did put the silverstar turn signals in and i have luminics titanium white for my lows and the stockers for my highs.. but i did take them out.. do those have to go in a certain way?
Old Apr 14, 2007 | 07:48 PM
SSKobald's Avatar
Mine do the same and and i never touch the LED's , however i did have a bulb blow about a month later and i replaced it with the same one. - I woulder if my LED's were wired wrong from the start. ? ....or maybe the wire i spliced together is not making a full connection?- ehh I'm looking into retro fitting them soon anyways.
Old Apr 14, 2007 | 11:33 PM
Jackalope's Avatar
If you were able to wire in the LED's with no problem then I doubt you screwed up putting headlight bulbs in. Check the harness like MK said. If you find its bad you may have to make your own plugs or hard wire the projectors in.
Old Apr 15, 2007 | 03:32 AM
VeNoM0713's Avatar
well do the bulbs have to be in a certain way? and how would i go about seeing if the harness is bad?
Old Apr 15, 2007 | 09:21 AM
Jackalope's Avatar
Do you have a test light? If not go to Pep Boys or who ever is near you and pick one up for light $5.00. Turn the lights on and start probing the wires to see if you have a short.
OR one at a time disconect the light bulbs and see if the problem goes away, if not reconnect it and move to the next bulb. I have these same projectors so if you need help with what color wires should be hot when let me know and I'll go check mine out since they work correctly.
Hey on a side note did you replace the little tiny halo LED's with 2 for each one like they are from the factory or did you use one big LED for each halo? Its a good idea I'm thinking of trying.
Old Apr 15, 2007 | 09:41 AM
mkulrey13's Avatar
im teling you, the problem is in the gray connector. mine did the SAME. the middle prong is not making a clean connection inside, its either bent shorter then others (hard to tell but it does happen) or the connectors inside the connector moved.
Old Apr 15, 2007 | 09:52 AM
Jackalope's Avatar
Thats why I told him to get a test light and check the wires cause he says his plug looks good. You can also unplug the lights one at a time and see if you can narrow down where the bad plug/issue is.
Still want to know 1 BIG LED or 2 small ones in the halo's?
Old Apr 15, 2007 | 03:19 PM
VeNoM0713's Avatar
i used 2 3mm led's for the halos.
Old Apr 15, 2007 | 03:25 PM
Jackalope's Avatar
Cool! Do you remember their voltage? Like 3.5 or 5.0 or 7.0 volt LED's? I've found some and plan to use the highest voltage ones i can find cause they should light up the brightest.
Old Apr 15, 2007 | 09:13 PM
VeNoM0713's Avatar
i dont know what voltage they were.. i got them form mkulrey13. he should know what they are.
TedSS
101
Apr 25, 2016 10:46 PM
Bluelightning
Nov 11, 2015 02:41 PM
chefhhr
Oct 26, 2015 10:36 PM
allpro666
Oct 6, 2015 08:11 PM
juandirtymessican
Oct 27, 2012 10:41 PM
