Projector retrofit help
Old Jun 22, 2009 | 09:51 AM
weiss27md's Avatar
I have looked at all the retrofit forums. I see people use E55, FX35/45, G35, and TL. I am wanting to use FX-R, has anyone used these? What projectors do y'all recommend and where did y'all get yours? I've just been looking at The Retrofit Source so far.
Thanks for any help.
Old Jun 22, 2009 | 10:05 AM
wardzach2007's Avatar
PM smartdude24
He does alot of retro's. Maybe he can give you advice.
Old Jun 22, 2009 | 01:05 PM
OriGinaL Condo's Avatar
He hasn't been responding to my e-mails lately. Not sure if its because his lights broke or cause he's away but you could give it a shot
Old Jun 23, 2009 | 09:13 PM
weiss27md's Avatar
I am wondering if I can use FX-R projectors but I'm also wondering when you switch to HID do you need to take out your DRL fuse?
I can't get a hold of smartdude24
Old Jun 23, 2009 | 09:27 PM
Tazmanian_Dvl's Avatar
DRL are the marker lights not the headlights.
Old Jun 23, 2009 | 09:47 PM
codytheoutlaw's Avatar
they were the headlights on my car. i disabled them.
i bought some fx35 projectors with clear lenses friday. im waiting on my headlight housings to come in now i have been wanting to do this forever. i bought my projectors on hidplanet.com. there is a lot of good info on that site. all i need now are bulbs, ballasts, harness, and shrouds and ill be set.
Old Jun 23, 2009 | 11:01 PM
Really that's strange. Every Cobalt I've seen has the marker lights as the DRL...
Old Jun 24, 2009 | 01:54 PM
blownss06's Avatar
I would go with an E55 projector with a clear lens swap, it will perform just as well as the FX and will be easier to mount. I made a set with the TL's and probably wont do it again, these were for my own car so I went the extra mile, because you have to make your own mount that mounts into the stock headlight and then you have to make a beauty ring because without that chrome reflector bowl you can see everything inside the headlight housing. It was a pain but came out pretty good. Here is a pic of my most recent set.
Old Jun 24, 2009 | 02:04 PM
DaBuzzard's Avatar
Guess you have never seen an 07+ 'Balt, because thats when GM went to the reduced voltage low beams as drl's.
To the op - yes, pull the drl fuse, the lower voltage will screw your ballasts......
Old Jun 24, 2009 | 02:14 PM
blownss06's Avatar
So thats what caused my ballasts to go, did not know that, thanks.
Old Jun 24, 2009 | 04:40 PM
hey blownss, do you have any more pics of your retrofit? i wanted to see how you mounted them and what they looked like before you put the lense on.
Old Jun 24, 2009 | 05:02 PM
weiss27md's Avatar
So I'm guessing E55s are the easiest to retrofit in, thanks
Old Jun 24, 2009 | 05:12 PM
blownss06's Avatar
Yeah and with a clear lens you will be very happy.
Old Jun 24, 2009 | 06:28 PM
hailcesar75's Avatar
what the hell is an fx-r???
Old Jun 24, 2009 | 06:32 PM
jefferyss's Avatar
smartdude is out of the country i beleave. dont sweat him 1 bit....he will respond once he is able to.
it has also been exams time here the last month and he is school first everything else second.
Old Jun 24, 2009 | 09:11 PM
weiss27md's Avatar
This is an FX-R, I think they just came out.
http://store.theretrofitsource.com/p...86fad5a2140eb6
Old Jun 25, 2009 | 03:47 AM
blownss06's Avatar
After looking at those in the link, they would be probably a little easier to mount than the E55's. They are new and made only by retrofitsource.com and come with a clear lens which is usually 50-75 dollar upgrade anyway. Those are nice, might have to get a pair.
TedSS
101
Apr 25, 2016 10:46 PM
SSnRXP
Dec 4, 2015 11:02 PM
Bluelightning
Nov 11, 2015 02:41 PM
chefhhr
Oct 26, 2015 10:36 PM
allpro666
Oct 6, 2015 08:11 PM
