Question about Gen 2 projectors
Old Jul 21, 2009 | 01:36 AM
slobalt08's Avatar
Is it possible to make the 3 LEDs on top blink with the blinker? I read somewhere it can be done. How can I do it?
Old Jul 21, 2009 | 01:48 AM
Cobalt08LS's Avatar
yeah just wire them into the turn signals.
Old Jul 21, 2009 | 01:51 AM
CobaltBoost407's Avatar
I would guess just wire those LED's into the blinker wire on the light/car...pretty simple?
Old Jul 21, 2009 | 01:58 AM
koch1ar's Avatar
won't that cause them to flash fast?
Old Jul 21, 2009 | 02:00 AM
slobalt08's Avatar
I'm not too good with wiring, can someone explain specifically what I have to do? Or a diagram or picture or something.
Old Jul 21, 2009 | 02:05 AM
Cobalt08LS's Avatar
no it should blink when you have your directionals on.
but im pretty sure if you do that, thats the only time they will be on.
unless you somehow wire them to your blinker and your parking lights. idk
my friend has his wired in his dodge ram they are wired to the turn signals and only are on when he puts his directional on.
Old Jul 21, 2009 | 02:09 AM
slobalt08's Avatar
The parking lamps go on as well as halos when the fog lights are on. I took the DRL fuse out because I have HIDs, so I use my fogs during the day. So they should stay on according to what you said. Now I just need to know how to make it work lol
Old Jul 21, 2009 | 07:23 AM
NCC-2000's Avatar
You can wire them into the turn signals directly and they'll blink normally, not fast, but that is the ONLY time the LEDs will turn on. To make them turn on with the parking lights and blink with the signals would require extensive wiring and use of relays and such to make it work.
Old Jul 21, 2009 | 12:07 PM
slobalt08's Avatar
Can you explain how to do it and what wires and such? What about making the halos do the same? Or can that cause premature wear to the bulbs cause they aren't meant to go on and off?
Old Jul 22, 2009 | 01:08 AM
slobalt08's Avatar
Old Jul 22, 2009 | 01:12 AM
EatonTVS07's Avatar
cant you hook the leds to an add a fuse and plug it into the fuse for the blinker?
Old Jul 22, 2009 | 04:22 AM
slobalt08's Avatar
I don't know I don't know anything about electrical, that's why I'm asking how it can be done.
Old Jul 22, 2009 | 05:59 AM
EatonTVS07's Avatar
im sure it would work but it would be a pain in the ass to get the wires for the leds on the passenger side hooked up.
Old Jul 22, 2009 | 07:46 AM
NCC-2000's Avatar
Easiest way to do it is to take all the wires for the LEDs and put the same colors together, usually they're black and white or black and red. Then just tap into the wires that are already at the headlight. Any black will work to connect the black wire bunch to, and the white or red bunch goes to the signal wire which I think is usually blue. That's it. Do that on both sides and the LEDs will blink with the signals.
Old Jul 23, 2009 | 04:47 PM
slobalt08's Avatar
Here's a diagram. It looks like all I have to do is tap the pink wire into the blue wire. Am I correct?
brandon04
Oct 21, 2015 07:04 AM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
