Rear SS Lip
Old Sep 1, 2006 | 12:52 AM
tonio5555's Avatar
Rear SS Lip
Will the rear SS/SC lip fit a 4 door cobalt? I upgraded to the SS exhaust setup now my exhaust tip hangs lower and looks kind of awkward on my car. With the lip from the SS I think itd make my rear end look just right.
Edit: (pics in post #18)
Old Sep 1, 2006 | 12:53 AM
articzap's Avatar
only if u have an ss rear bumper
Old Sep 1, 2006 | 01:04 AM
tonio5555's Avatar
Well I know the SS rear bumper won't fit a 4 door.. so I guess I'm out of luck? I'd pick up the RK sport rear valance, but I don't like the fact that it has 2 exhaust cut outs while I'l only going to have 1 in use.
Old Sep 1, 2006 | 02:04 AM
roccobladr's Avatar
try the 2.4 ss lip
Old Sep 1, 2006 | 11:40 AM
tonio5555's Avatar
Anyone have a decent picture of the 2.4 SS rear? Preferably the sedan but coupe images will work as well. I've tried searching these boards and google but I just can't seem to find one.
Old Sep 1, 2006 | 07:44 PM
articzap's Avatar
2.4 ss bumper is the same as a 2.0 rear bumper? 2.0 jsut adds a lip to the 2.4 bumper
Old Sep 3, 2006 | 08:01 PM
Badmunky's Avatar
Try the G5 rear lip. Im going to change to that as soon as I find out if it will fit the Cobalt rear bumper.
Later
Old Sep 3, 2006 | 08:14 PM
RaineMan's Avatar
2.4 SS rear bumper isn't the same as the SS/SC rear bumper.
I can provide y'all with some pics of what the SS/SC bumper looks like under the lip (courtesy of my being rear ended). Check my "Rear Ended!" thread in Member's Rides for a few shots. I'll post more if you want.
The SS/SC rear has slots cut in it and some screw tabs on the bottom for the lip to mount too. I don't know anything about how the G5/Pursuit lip mounts up... but I'd bet it uses the SS/SC rear bumper and is just a different lip.
The 2.4 has a special plastic mesh section that hangs down from the bumper. I don't think that it would mount to a LS/LT bumper either... but it'd be cool to line a LS/LT 2.4 and SS/SC up side by side and see the differences.
Old Sep 4, 2006 | 01:07 AM
Badmunky's Avatar
Tje G5 uses the 4 door tail lights on the coupe. Its not the same rear bumper but Im hopeing GM used the same slot patern whne they made it. It is sloted like the Cobalt is. Just dont know if it will line up or not.
Later
Old Sep 4, 2006 | 08:00 AM
g5mike's Avatar
Try the g5 rear lip, it is a full lip
Old Sep 4, 2006 | 09:37 AM
StealthSS's Avatar
is it just me, or is the G5 "lip" not a lip at all. looks to me like its just part of the bumper and is designed to look like an attached lip by having that raised line. basically it looks like a one piece bumper with a raised groove around it.
Old Sep 4, 2006 | 04:21 PM
g5mike's Avatar
You would think it is part of the bumper, but the lines are so good it blends in perfectly.the g5 rear lip is actually lower than the ss/na hiding more of the underneath of the car
Old Sep 4, 2006 | 04:27 PM
09G5GT's Avatar
Later
The G5 coupe and sedan use DIFFERENT TAILLIGHTS. They look similar but they're not. Damnit why am I the only one that knows this....
Old Sep 4, 2006 | 04:28 PM
bavoose's Avatar
is it me or is that a disabled parking spot?
Old Sep 4, 2006 | 04:34 PM
g5mike's Avatar
After the installer was done doing my stripes he parked it there
Old Sep 4, 2006 | 05:24 PM
tonio5555's Avatar
I'm going to take a picture of the rear end of my car and I'll show you guys my issue with the way the SS Exhaust looks.
Old Sep 4, 2006 | 05:50 PM
RaineMan's Avatar
I know the issue you have...
the SS exhaust "droops" after the muffler to the tip... so it can clear the lower bumper...
LS/LT exhaust is straight....
Old Sep 4, 2006 | 06:14 PM
tonio5555's Avatar
Exactly!
Sorry for the dirt, my car is usually CLEAN.
All I want to do is close that gap, whether that means a lip, new bumper, etc.. how do I close that gap?
Old Sep 4, 2006 | 06:17 PM
g5mike's Avatar
Exactly!
The g5 gt lip will perfectly accomadate you,if you are buyin a lip you might as well get this one over the ss/na
Old Sep 4, 2006 | 07:37 PM
biohazard's Avatar
Get low
same outer shape though which is what he was talking about.... the only diff is the reverse lights being frenched into the bumper on the G5 if im correct
Edit: o nvm the sedan looks like the trunk goes \______/ where the G5 is more like |_____|
Old Sep 4, 2006 | 07:59 PM
g5mike's Avatar
But really he does not need the bumper just the lip, and it will work on all models
Old Sep 4, 2006 | 08:12 PM
RaineMan's Avatar
The easiest and cheapest way would be to go to a muffler shop... have them cut off the "drooping" tip and putting on a new, straight one.
Old Sep 4, 2006 | 09:31 PM
g5mike's Avatar
Thats what pengquin pie did
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
nathan112i
Sep 30, 2015 07:12 PM
Delta coupe
Sep 30, 2015 08:11 AM
