remove emblems help!
Old Jun 6, 2007 | 07:23 PM
pnoi604's Avatar
Hey,
sorry i don know too much bout cars, but i've been having troubles removing the front chevy emblem on grill, i tried using a 10mm ratchet and it wouldnt work, 9 mm is too small, any ideas? And also I want to remove the back one as well, if you could hlep me out with that too thanks guys.
Old Jun 6, 2007 | 07:30 PM
killah_thug08's Avatar
get tooth floss or a fishing string, and a hair dryer,
put hair dryer on emblem for like a min or 2
slide the tooth floss or fishing string between the emblem
spray goo gone
let it sit for 5min
use ur finger to remove the stcky stuff
Old Jun 6, 2007 | 07:34 PM
D4u2s0t's Avatar
the front one has a weird type of "bolt" on it. i don't know how to describe it other than it twists once or twice, and pushes on. twist a couple times i believe with the 10mm, then just pull it off.
Old Jun 6, 2007 | 08:46 PM
sscobaltscZ06's Avatar
The front one really isnt a typical nut. Its a half twist fastener thats I think 10mm but it comes off easy. I just took the front emblem off, but the idiots somewhere along assy drilled 4 holes for the 2 stud emblem.
Fishing line works excellent and the hair dryer only needs to be held on it for 20 seconds or if its on a hot day sitting in the sun hair dryer is not needed. It took 10 mins to remove all the emblems.
Old Jun 6, 2007 | 08:54 PM
quickspec's Avatar
How do you remove the other emblems?
Old Jun 6, 2007 | 09:32 PM
Credit card is the worst f-ing way to remove badges unless you want scrapes on your clear coat. Get a blow dryer and hold it over badge for 30 seconds and then take some low strength fishing line (it might break a few times, but no big deal) under/against the badge between the badge and badge side of glued foam and saw it back and forth holding the line outward (do not saw it back and forth resting agains the paint). It will cut the badge away from the foam leaving the foam on the car and paint untouched.
Took my son and me a whole 10 minutes to remove all the badging and another 30 minutes to remove the foam off the paint and clean it afterwards. The only badging foam that required goo gone to remove the foam was the small gm emblems on the side. All the others the foam just peeled away very easily, but the rear large Chevy emblem took a while longer as the foam wasnt as thick and harder to pull off.
Old Jun 7, 2007 | 05:20 PM
pnoi604's Avatar
yea i tried using a 10 mm and it wouldnt turn.
Old Jun 7, 2007 | 06:14 PM
It'l turn if you are going the right direction removing it and it only takes 1/2 turn or so to release it. It might be stuck on but it will eventually turn. The 10mm fastener/nut doesnt have any threads so it sorta cuts into/fits tightly onto the plastic stud threads, so it sticks very tightly alot of times.
Old Jun 7, 2007 | 07:08 PM
xspyder85x's Avatar
just get a small pair of pliers.
Old Jun 7, 2007 | 07:35 PM
ecotecon18s's Avatar
Vise-Grips/Channel Locks FTW!!!
Old Jun 7, 2007 | 08:24 PM
Man if you guys cant get those fasteners off with a simple twist of a 10mm socket, then you got some serious simple mechanical deficiencies and I dont even wanna think about you trying to change the oil filter...
Old Jun 7, 2007 | 11:00 PM
tiny's Avatar
its typical 10mm bolts, use a simple wrench, it'll work
with the other emblems, use the plastic fishing line, not the metal kind
and use goo gone to clean off the glue, then wax it after
Old Jun 7, 2007 | 11:02 PM
alaskacobalt's Avatar
You can do the method that I used... I drove off the parking lot after purchasing it, looked at it when I got home and realized it was being held on by glue, the bolt holes were drilled, but nothing was there. It was just sort of dangling there... so I bolted it in and now I'm thinking about removing it. ;0
Old Jun 7, 2007 | 11:50 PM
Once removing the front emblem does anyone else have 4 holes under it also? Im guessing some robot misdrilled from a bad setup program for the front badge and they had to be redrilled by hand after the fact to install the emblem later on down the line.
Old Jun 7, 2007 | 11:57 PM
camarokiller's Avatar
They have to find it first.
Old Jun 8, 2007 | 11:25 AM
pnoi604's Avatar
haha no i don't have mechanical defficiancies. I know it's a simple job but for some reason with whatever size socket and whoever tries, the botl wont twst, but yea lolz thanx guys for tha info i guess ima have to keep tryin then =S
Old Jun 8, 2007 | 02:14 PM
kkanowitz's Avatar
Trying to remember when I painted mine, I noticed the holes also. There are two other little pegs (beside the little screw ones) on the back of the emblem that go inside of those two extra holes. So they aren't there for nothing.
Old Jun 8, 2007 | 06:53 PM
Mine only has one extra peg on the backside. Its a typical design foul up typical on all cars. 3 studs 4 holes... yea thats correct... LOL
Decepticon06ss/sc
Oct 16, 2015 09:24 PM
Extreme Dimensions
Sep 24, 2015 05:24 PM
dieGone
Sep 23, 2015 10:20 AM
katahdin_lubricants
Sep 20, 2015 07:24 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
